Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL December 04, 2017 12:49PM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 13, 2018 11:28AM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 13, 2018 11:58AM |
qwazix
Despite most designs now using direct drive extruders the people over at duet3d state that you need 75Ncm torque.
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 13, 2018 12:06PM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 15, 2018 10:27AM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 17, 2018 03:49AM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 17, 2018 04:09AM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 17, 2018 07:02AM |
qwazix
The extruder carriage is modular and I will do what you suggest as an option, later on. For now, priority is to make it reliably print with two nozzles (thus bowden) because I desperately want to print buildings (which are unprintable without soluble support material, due to overhangs).
I would very much like to use something like titan but I want to build a fully open source machine and while titan assembly drawings mention GPL, the actual manufacturing drawings (or models) are nowhere to be found. I'd rather not design my own extruder right now, though it's something I might do one day.
If you have any idea for extruders give a shout.
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 17, 2018 07:19AM |
MKSA
As someone proposed it somewhere, use a Bowden for the support filament and a direct extruder fro the "build".
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL March 15, 2018 07:13AM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 14, 2019 11:01AM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL February 14, 2019 01:23PM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 20, 2022 10:59AM |
Re: Announcing Rosalind, a parametric CoreXY 3D printer designed in OpenSCAD and licensed under the GPL January 31, 2022 07:04AM |
