Cable management to the X-Y carriage - how did you do it? January 31, 2018 10:16AM |
Re: Cable management to the X-Y carriage - how did you do it? January 31, 2018 12:20PM |
Re: Cable management to the X-Y carriage - how did you do it? January 31, 2018 02:03PM |
Re: Cable management to the X-Y carriage - how did you do it? January 31, 2018 02:37PM |
Re: Cable management to the X-Y carriage - how did you do it? January 31, 2018 07:50PM |
Re: Cable management to the X-Y carriage - how did you do it? February 01, 2018 03:20AM |
Re: Cable management to the X-Y carriage - how did you do it? February 01, 2018 07:19AM |
Re: Cable management to the X-Y carriage - how did you do it? February 01, 2018 08:01AM |
Re: Cable management to the X-Y carriage - how did you do it? February 01, 2018 10:13AM |
Re: Cable management to the X-Y carriage - how did you do it? February 01, 2018 11:37AM |
Re: Cable management to the X-Y carriage - how did you do it? February 01, 2018 08:47PM |
Re: Cable management to the X-Y carriage - how did you do it? March 08, 2018 12:01AM |
the_digital_dentist
I think that if you buy commercial drag chain you'll find the tolerances much tighter and it will last longer. Drag chain is cheap stuff- there's no reason to print it when the commercial stuff is so cheap and performs so much better.
I use a horizontal drag chain in my printer, but I have it arranged in a very large, gentle loop. It looks like you have it anchored to the frame along the right side which will force it to curl in a pretty tight radius. Besides wearing out your printed drag chain, that will cause wire breakage eventually, and that can be a difficult problem to isolate because the wires break inside their insulation and become intermittent. If the motor driver leads become intermittent, they can destroy the motor driver chip.
Here's my drag chain- it anchors on the left side and curls around the extruder carriage a full 360 degrees where it anchors at the left front of the extruder carriage. I does require extra length to do that, so it droops a bit, but it doesn't flex any of the wires in a small radius.
You might be able to see it better in this picture- the drag chain anchors on a small piece of metal attached to the printer's frame on the left side where all the cables are, with the opening facing the front of the printer, then curls around and attaches to the extruder carriage with the opening facing the back of the printer.
Re: Cable management to the X-Y carriage - how did you do it? March 08, 2018 10:05AM |
Re: Cable management to the X-Y carriage - how did you do it? March 09, 2018 10:13AM |
Re: Cable management to the X-Y carriage - how did you do it? March 09, 2018 10:34AM |
