Large CoreXY Z Lift February 13, 2018 03:51PM |
Re: Large CoreXY Z Lift February 13, 2018 04:16PM |
Re: Large CoreXY Z Lift February 13, 2018 05:13PM |
Re: Large CoreXY Z Lift February 13, 2018 10:48PM |
Re: Large CoreXY Z Lift February 14, 2018 04:05AM |
Re: Large CoreXY Z Lift February 14, 2018 07:45AM |
Re: Large CoreXY Z Lift February 14, 2018 08:14AM |
Re: Large CoreXY Z Lift February 14, 2018 01:41PM |
the_digital_dentist
That sounds like a great idea. It only needs to move up and down a little. so it might be easiest to do using a solenoid and lever. A simple gcode post-processing script could be used to insert lift/drop commands into the gcode file to drive a solenoid. Just add lift after every retraction and drop just before extrusion restarts
Re: Large CoreXY Z Lift February 14, 2018 04:44PM |
oz9ny
the_digital_dentist
Problem with a selenoid is that you may be very dependant of gravity. Stepper and small screw will be better and more precise in my opinion.
oz9ny
the_digital_dentist
Re: Large CoreXY Z Lift February 14, 2018 05:01PM |
Re: Large CoreXY Z Lift February 14, 2018 10:25PM |
Origamib
It doesn't need to be precise, it only needs to return to the same position each time. ...
Re: Large CoreXY Z Lift February 16, 2018 06:08AM |
