Re: CoreXY March 04, 2018 12:43PM |
Re: CoreXY March 04, 2018 07:14PM |
Re: CoreXY March 05, 2018 03:33AM |
Re: CoreXY March 05, 2018 03:36AM |
Re: CoreXY March 05, 2018 06:49AM |
Re: CoreXY March 05, 2018 01:13PM |
Re: CoreXY March 07, 2018 06:11AM |
Re: CoreXY March 12, 2018 04:58AM |
Re: CoreXY March 12, 2018 09:55AM |
Re: CoreXY March 12, 2018 10:49AM |
Re: CoreXY March 12, 2018 07:23PM |
Re: CoreXY March 12, 2018 09:29PM |
kapperi
the_digital_dentist
I wouldn't let my dog (if I had one) use 2020 to build a 3D printer. Go with the larger stuff.
Ball screws will probably allow the bed to drop when power to the Z motor is cut, if everything is aligned well.
I definitely would not mix bearing blocks and rails from different manufacturers. Linear guides are systems, not parts.
So do you think I go with the 3030 or is 2040, you build your megamaxsuperhyperturbo with 4040? So I think with much less Z, I could go with 3030.
Ball screws will allow the bed drop, but could I use geared Nema to stop that?
Edit: God tha PLA is so easy to print. If only it could come in better strength..
Re: CoreXY March 13, 2018 01:26AM |
the_digital_dentist
Others have tried using screws without guides and the result is never pretty.
Vigilant
I suggest that you use 4040 that is consist of 2 2020 if you want it more rigid. A lot of hardwares sold are based on 2020 mounting.
MIsumi 40X40
Re: CoreXY March 13, 2018 11:01AM |
kapperi
the_digital_dentist
Whats the problem? Only the lift is using ballscrews as a guides and the bed is constrained properly with bearings.
Re: CoreXY March 13, 2018 12:44PM |
Re: CoreXY March 13, 2018 01:40PM |
Re: CoreXY March 13, 2018 01:46PM |
Re: CoreXY March 13, 2018 11:18PM |
Re: CoreXY March 14, 2018 01:54AM |
Vigilant
MIsumi 40X40
Re: CoreXY March 14, 2018 11:40AM |
Re: CoreXY March 14, 2018 02:40PM |
Re: CoreXY March 14, 2018 04:42PM |
Re: CoreXY March 15, 2018 01:02PM |
Re: CoreXY March 22, 2018 08:54AM |
Re: CoreXY April 27, 2018 01:23PM |
Re: CoreXY April 27, 2018 02:59PM |
Re: CoreXY April 27, 2018 03:39PM |
Re: CoreXY April 27, 2018 03:44PM |
