Z axis gantry vs Z axis printbed March 09, 2018 01:23AM |
Re: Z axis gantry vs Z axis printbed March 09, 2018 11:03AM |
Re: Z axis gantry vs Z axis printbed March 09, 2018 11:15AM |
Re: Z axis gantry vs Z axis printbed March 09, 2018 05:46PM |
Re: Z axis gantry vs Z axis printbed March 10, 2018 02:41AM |
Re: Z axis gantry vs Z axis printbed March 10, 2018 08:28AM |
Re: Z axis gantry vs Z axis printbed March 12, 2018 09:13PM |
the_digital_dentist
I made a printer with 300 mm square bed using belts to lift it in the Z axis (700 mm) and it's working well (click the Ultra MegaMax Dominator link in my sig, below). I would not lift the XY stage unless the printer is really big making it impractical to lift a much more massive bed. I have tested the Z axis in my printer to lift a 4 kg print mass (and the bed assembly weighs about 3.5 kg) at 20 mm/sec. It uses a 30:1 worm gear reducer to prevent the bed from dropping when power to the Z motor is off. It works perfectly.
The Rino worm gear reducer is a relatively expensive part to use- it and the keyed 8mm output shaft cost about $140. I have located some worm gears from a Chinese supplier and await delivery to test a printable gearbox I have designed. It will reduce the cost of using a worm gear reduction for a similar Z axis to about $40.
One of the other issues with moving the XY stage up and down is that the cables have to be lengthened and controlled. The bed has only heater and thermistor leads to deal with.
Re: Z axis gantry vs Z axis printbed March 12, 2018 09:15PM |
Origamib
The biggest challenge with an XYZ moving gantry is keeping it rigid. A flat bed on Z is easy to keep rigid and can be kept relatively light as a result. With an XYZ frame you have a square that will act a bit like a picture frame when you take the glass out. You can reinforce it, but in practice its a lot easier to have a bed that moves in Z.
Re: Z axis gantry vs Z axis printbed March 12, 2018 09:23PM |
MKSA
What is the easier to make and keep square ?
See also this: [forums.reprap.org]
In doubt, go Delta !
Re: Z axis gantry vs Z axis printbed March 12, 2018 10:03PM |
Vigilant
Curious, why didn't you try a 2 stage gear reduction using pulley and closed loop belts? Maybe 2 (4:1) to give 16:1 reduction. GT2 pulleys of various sizes are very common and I think GT2 backlash is going to be better than gearboxes.
Re: Z axis gantry vs Z axis printbed March 13, 2018 05:35AM |
the_digital_dentist
Re: Z axis gantry vs Z axis printbed March 13, 2018 08:01AM |
