Hbot Motor inverted
Posted by mogey336
Hbot Motor inverted
March 19, 2018 09:54AM
I made Hbot 3D printer but i have a problem that the motors are inverted, the homing in the upper left i tried to reverse the motor cables but the homing was front right.
Any advice ?
open | download - DSC_3447.JPG (68 KB)
open | download - DSC_3449.JPG (59.6 KB)
Re: Hbot Motor inverted
March 19, 2018 10:39AM
Limit switch locations and origin are not necessarily the same thing.
When you send a home command, the motors have to turn in the direction that will bump the end stop switches. The switches can be located at either the minimum or maximum of the X and Y axes, but the origin (coordinates 0,0,0) has to be at either the front left corner or the right rear corner of the machine. You have to make appropriate settings in the firmware and plug the endstop switches into the right connections on the controller board. There is a full explanation here: [drmrehorst.blogspot.com]
March 19, 2018 06:22PM
Thanks for your amazing instruction in your blog, I swapped the X and Y motors and make Y limit switch go to Max not Min and works fine now
March 19, 2018 07:18PM
I'm glad it was useful...
