E3D's tool changing CoreXY design March 21, 2018 02:34PM |
Re: E3D's tool changing CoreXY design March 21, 2018 07:24PM |
Re: E3D's tool changing CoreXY design March 21, 2018 10:56PM |
Re: E3D's tool changing CoreXY design March 21, 2018 11:47PM |
Re: E3D's tool changing CoreXY design March 22, 2018 03:22AM |
prot0typ1cal
Looks pretty sweet!
Makes me sad to have spent so much time on CoreXYU
No reference to the final price, so making a deposit is questionable.
Perhaps the firmware will be open source so I can convert my CoreXYU to a tool changer?
Sounds like maybe the tidbits will be offered seperately instead of a complete kit...
Yea, I'd have to ditch the RADDS/Due for a Duet, but hey, be worth it.
Re: E3D's tool changing CoreXY design March 22, 2018 05:49AM |
Re: E3D's tool changing CoreXY design March 22, 2018 09:42AM |
Re: E3D's tool changing CoreXY design March 22, 2018 10:20AM |
Re: E3D's tool changing CoreXY design March 23, 2018 12:44AM |
Re: E3D's tool changing CoreXY design March 23, 2018 06:53PM |
the_digital_dentist
I can't understand why anyone is still designing printers that use 4 screws to level the bed.
Yeah, I know- autoleveling.
If no effort is made to make the bed flat and level, when the autoleveling fails you're not going to print. A bed that size can easily be made flat and level and you can still use autoleveling if you feel you must have it, but you'll still be able to print when the autoleveling fails.
Re: E3D's tool changing CoreXY design March 24, 2018 01:41AM |
Re: E3D's tool changing CoreXY design March 24, 2018 07:46AM |
Re: E3D's tool changing CoreXY design March 24, 2018 08:12AM |
Re: E3D's tool changing CoreXY design March 24, 2018 09:24AM |
the_digital_dentist
I would assume (and I may be wrong) that the plastic oozing out of the nozzle when it sits idle but hot is due to plastic just above the normal melt zone in the hot-end melting as heat creeps up the filament. As the plastic heats it expands and pushes molten filament out the nozzle. If you block the nozzle, the molten filament is going to have to go somewhere, so it's going to go up instead of down and out. I'm not sure that's a good thing to do. Maybe it's better to let it drool and wipe the drool off when the machine picks up the tool...
Re: E3D's tool changing CoreXY design March 24, 2018 12:54PM |
Re: E3D's tool changing CoreXY design March 24, 2018 05:41PM |
Re: E3D's tool changing CoreXY design March 24, 2018 10:25PM |
The alu base plate sold me too !!Quote
ampapa
Couldn't you just retract the filament beyond the heater and then after a tool change just pre-feed some material? doesn't seem like a big deal to me but maybe I'm over simplifying.
A tool change doesn't have to be fast it just has to be accurate.
I was thinking about the tool change concept and the accuracy after a tool change, not necessarily about the mount itself but the tool tip to the bed. How are each of those tool heads going to be setup exactly the same... I don't think it can happen.
On my CNC when a tool change is needed it has to use a "touch off" to account for the difference in tool height.
I wonder how that is being accomplished? I might be answering my own question but possibly each unit has a BL Touch?
I'm currently re-designing my CoreXY and I really like the XY axis design on an aluminum plate, gonna borrow that design.
ampapa,
Re: E3D's tool changing CoreXY design March 25, 2018 05:14AM |
ampapa
ampapa
Re: E3D's tool changing CoreXY design March 25, 2018 08:14AM |
Re: E3D's tool changing CoreXY design March 25, 2018 08:29AM |
Re: E3D's tool changing CoreXY design March 25, 2018 08:52AM |
ampapa
@bigfilsing @DC42, I get the offset settings but I'm still not sure that will solve the problem.
Maybe I'm misunderstanding how the tool change works but it looks like they each have a home on the back plate held in place magnetically and on homing rods. Each tool I assume has its own heater, hot end and fan. So, essentially they are identical in configuration but when you change from one tool to another it's not possible that they are all the same length and therefore the tip to bed measurement will be different, offset or not, at some point the offset has to be measured against the bed to be useable, isn't that correct?
Re: E3D's tool changing CoreXY design March 25, 2018 08:57AM |
dc42
I think the main reason for oozing is residual pressure in the Bowden tube pushing the filament out. If I am right, the amount of oozing should be much less with direct drive extruders; but I don't have any of those to compare with.
It's normal to reduce the temperature of idle tools to somewhat below normal printing temperature, e.g. 150C for PLA. This will cause the already-molten filament to contract.
If you are right and the filament does expand significantly overall, then my expectation would be that the amount of expansion is going to be small and with the nozzle blocked it will push the filament a tiny amount up the heat break, not far enough or quickly enough to cause a filament jam. In Bowden systems (which they are mostly using), there is plenty of slack in the Bowden tube to handle the expansion. In direct drive extruders there will be less; but if necessary the extruder motor current could be reduced for idle tools in order to relax the pressure.
Like you I am surprised they went for 4 bed levelling screws. However, they are using a PCB bed heater, which isn't as rigid as cast aluminium. Maybe it is sufficiently flexible that 4 screws are better than 3 in this case. Personally I would choose cast aluminium and a silicone heater, with either 3 levelling screws or 3 independently-driven leadscrews instead of the single leadscrew cantilever design.
Re: E3D's tool changing CoreXY design March 25, 2018 09:02AM |
motley
It looks amazing - not just the tool changing but the motion system as well.
I'm in the queue...
Re: E3D's tool changing CoreXY design March 25, 2018 09:15AM |
the_digital_dentist
Re: E3D's tool changing CoreXY design March 27, 2018 01:35PM |
Re: E3D's tool changing CoreXY design April 02, 2018 09:01PM |
Re: E3D's tool changing CoreXY design April 06, 2018 01:48AM |
Re: E3D's tool changing CoreXY design April 07, 2018 08:30AM |
