Reverse Z axis in pronterface
Posted by mogey336
March 30, 2018 11:16AM
I made Hbot printer but z axis is reversed in pronterface how can i correct it?
Re: Reverse Z axis in pronterface
March 30, 2018 11:25AM
When you home the machine does the Z axis move in the right direction?
March 30, 2018 01:23PM
Yes , it moves to the proximity switch
March 30, 2018 01:42PM
And is the switch at the Z=0 position (bed at the top of the Z axis)? Is the switch plugged into the Zmin input port on the controller?
March 30, 2018 05:47PM
The switch on the top. When autobed leveling (G29) it moves to the top and auto level it self , I use the Zmin
March 30, 2018 07:19PM
Positive and negative in Z are relative. The pronterface UI has positive Z up. Think of it not as the bed moving down, but the nozzle moving up relative to the bed. When you tell pronterface to move up 10mm, the nozzle is moving 10 mm above the bed. In your machine the bed moves down, in other machines the nozzle moves up. It's the same thing.
