bed still not levelled after G29
Posted by golfox2
June 05, 2018 05:03PM
Hi everyone, I have an issue with my SmartCore (RepRap, Marlin) 3D printer. It has the G29 feature to level the bed according to a probe, but it does not compensate for what it should at the back of the plate.
- I tried to over "de-level" the bed (like 2cm and it still compensates so the G29 command works) but in any case, the back is too close to the head, and the front is fine.
- I replaced every pieces of the X-Y axis yet the issue remains.
- I use aluminium tape under my glass bed for probing.
- It is a Core XY printer (see image attached for more details)
Do you have any idea, even the smallest, to my problem ?
Does an individual offset for each 4 points probed exist in the firmware ?
Thanks a lot guys winking smiley
pictures of the problem here :
overall printer :
bed from front
bed from above
Edited 2 time(s). Last edit at 06/05/2018 05:04PM by golfox2.
Re: bed still not levelled after G29
June 06, 2018 02:03AM
What happens if you de-level the bed downward in the back so it it too low in back. Does it then make the front too close to the bed? Where does it start leveling? Front left? Front Right? Back Left? Back Right?
-os3dp
June 06, 2018 03:02AM
The cable guide looks pretty rigid. Does the inductive probe tilt, when you are probing at the back of the bed?
Do you still get bad level, when you move the MK3 heated bed elsewhere? It might have some influence on the probe...
June 06, 2018 05:04AM
Hi, sorry I didn't precise, it probes front-left, then front-right, then back-right, then back-left. 4 points in total.
It does not change anything, if I de-level, in any way, the printer still compensates, but will do the same problem even with a maximum tilt angle.
I thought about that being an issue, I tried without and it was not any better. So I put it back.
Indeed that could be something, I'll try it asap, thanks for the idea
Thanks guys, I hope we will be able to solve this winking smiley
Edited 1 time(s). Last edit at 06/06/2018 05:04AM by golfox2.
June 06, 2018 04:48PM
Check the glass thickness too, your measuring the bottom and printing on the top, or rotate the glass to see if it changes
June 07, 2018 05:05AM
The thing I don't understand is that it was working a few weeks ago, and suddenly, stopped working.
In fact, my hot-end fixation just melted after the fan didn't start one time. So I thougt that was the issue, and I replaced the defective parts. But no result.
Yes I also tried to rotate 90, 180, 270° de glass plate, same, no improvement.
June 07, 2018 05:07AM
Do you guys think something exists to set an offset for each probe point here in the configuration.h of the software ?
I'm in linear auto bed leveling
#if ENABLED(AUTO_BED_LEVELING_LINEAR) || ENABLED(AUTO_BED_LEVELING_BILINEAR)
  // Set the number of grid points per dimension.
  #define GRID_MAX_POINTS_X 2
  #define GRID_MAX_POINTS_Y GRID_MAX_POINTS_X
  // Set the boundaries for probing (where the probe can reach).
  #define LEFT_PROBE_BED_POSITION 5
  #define RIGHT_PROBE_BED_POSITION 130
  #define FRONT_PROBE_BED_POSITION 15
  #define BACK_PROBE_BED_POSITION 145
That would surely solve the problem I guess
July 04, 2018 09:16AM
hey, up =)
