CoreXY or Ultimaker gantry
Posted by karl0508
June 20, 2018 05:09AM
Hi Guys
I currently have a Prusa I3 clone, i love it, i use a bowden extruder and use it for PLA and PETG
I would now like to make a CoreXY machine of my own design, however because i have not got any experience with a CoreXY machine i would like some opinions.
I plan on having a 150×150×150mm build area.
So my biggest question is what are the advantage of the CoreXY vs the ultimaker gantry?
I have attached an image of the concept i had started, please not i have 2 X gantries in the model, this is only to make sure the hotend can move all the way to the correct build area
open | download - corexy.jpg (124.5 KB)
Re: CoreXY or Ultimaker gantry
June 21, 2018 01:32AM
A CoreXY can use fully supported linear rails, while Ultimaker only uses end supported smooth rods. The difference will show up on bigger scale printers, but 150x150 will not be critical.
June 21, 2018 12:53PM
So do you think at 150×150 corexy is worth it, or will a prusa style be just as good? Or even a delta
June 21, 2018 05:28PM
To be honest, a cartesian would be the simplest here. Your bed isn't huge so you don't have to worry about mass. If you're going to build either, at least go a little bigger to make the extra cost worth it.
June 21, 2018 05:36PM
I wanted to try make the smallest printer possible with a 150×150 build area to take traveling, i have the prusa so was thinking something smaller would be nice smiling smiley
May even go belt on Z axis like the lulzbot mini 2
June 21, 2018 06:27PM
have a look at the "dice" printer for some good ideas on getting small corexy
dice
June 21, 2018 09:21PM
Maybe some mgn7 rails.
June 22, 2018 02:26AM
Perhaps a corexy machine like dice but using Fireline, would allow you go put idlers closer together, reduce the size of the XY joiner.
Anything to reduce foot print, i could also look to make a single printable plate that all the mechanism mounts to.
Sort of like the original CoreXY steel plate
June 22, 2018 02:56AM
I would keep away from fireline especially on a small printer, the line tends to walk on the drive pulley which alter the length
June 22, 2018 03:02AM
Could do what E3D have done and use an extra idler to bring the belts together.
The problem i always have with small printers is because we still use Nema 17 the mechanics still have to be so large, nema 14 would be better as they would take less percentage away from the print area.
Suppose thats one of the advantages of ultimaker gantry as you can mount the motors is such a way you don't have that as an issue
June 22, 2018 04:42AM
adambrum
I posted a 'crossed' version of line pulleys, which eliminates the length-issue.
June 22, 2018 04:44AM
o_lampe
adambrum
Could you please share me a link? this would allow the lines to be closer than 13 mm which the belts have as a gap, this would reduce overall foot print
June 23, 2018 03:06AM
It starts on page 2 of this thread, but it's worth reading it from the beginning:
replace belts with FireLine
June 23, 2018 11:25AM
An observation about pulleys used with cable: in all the drawings the cable is coming off the pulleys at an angle and it seems you're relying on the pulley to find its position to wrap on the pulley by using the already wrapped cable as a guide, and it always occurs at and angle to the desired motion- the cable is not parallel to the guide rail.
Is there some reason you don't put "threads" in the pulleys to guide the cable straight? If one pulley is left hand threaded and the other is right hand threaded the cable will come off and go onto the pulleys parallel to the guide rail and there will be no danger of the cable getting crossed and feeding at any other angle. Such pulleys would be printable, except that they may not hold up well under the forces applied by the tension on the cable. They would not be hard to turn on a lathe. Something like this:
I think this technique was used in cable driven plotters for years.
Or maybe I'm misunderstanding what is being described...
June 23, 2018 10:13PM
I did something similar years ago.
[3dprinterhell.blogspot.com]
It works fine, but IMO it’s just not worth the effort, belts and pulleys just aren’t that expensive anymore.
I’ve built both corexy and ultimaker style gantries, I prefer the latter, but if the corexy design is sufficiently rigid they work fine as well. In fact my current project is a corexy design.
___________________________________________________________________________
My blog [3dprinterhell.blogspot.com]
June 24, 2018 01:27AM
The cable runs parallel, that's right, but it also wanders up/down the pulley. ( a lot more than without thread )
In my setup you can see that one cable runs parallel to the rail too and only needs 4.2mm pulley length for 20cm travel. ( 0.5mm cable )
The angle of the returning cable is pretty steep, but it spools up nice and reliable. I tested a honeycomb-savey gcode file at 200% speed without issues.
June 24, 2018 10:01AM
Ah! I see it now.
polygonhell- how is the pulley arranged at the far end- the line on the drive end is coming off and going onto the drive pulley at two vertical levels. Do you set the far-end pulley groove at the same level as the top or bottom of the drive end? Isn't the cable rubbing against the offset drive pulley all the time?
I'm getting ready to build a large corexy mechanism for a sand table and was thinking of trying cable drive. This is just what I need, I think.
Edited 1 time(s). Last edit at 06/24/2018 10:03AM by the_digital_dentist.
June 24, 2018 11:19AM
It’s arrranged so the side that needs to be parallel for linear motion is.
I used v-groove pulleys, the angles are negligible for any reasonably sized axis.
The bigger issue is the angles between the grooves in the 2 drive pulleys, once the line is tensioned, you can hear the line as it comes in and out of the grooves.
It worked fine and it’s trivial to machine.
This might give you a better idea how the entire thing worked
[m.youtube.com]
I never really used the mechanism in anything other than proof of concepts, my concern would be that unlike with belts where there is effective registration on every tooth line could accumulate error. I did run tests over days, and couldn’t measure significant errror so maybe i’m just overthinking it.
The original tantilus mechanism effectively fixes the line, so it can’t accumulate error, but it was a pain to tension, and the drive angle varied with motion, it really didn’t matter because of the small print size.
Back when I made it a lot of people were playing with line instead of belt, there were a lot of Kosel variants using line, you simply couldn’t buy cheap belt and pulleys.
I’ve built a lot of printers, and I just reached the point of it’s not worth saving a few dollars for a potentially significant mechanical compromise.
On the original topic, the reason I prefer ultimaker style gantries over CoreXY, is if you don’t Align them properly they just don’t work. When I first played with CoreXY reasonably priced linear rails were unobtainable, and they really need a degree of rigidity in design that’s not easily obtained with rods and bearings.
Edited 2 time(s). Last edit at 06/24/2018 11:36AM by Polygonhell.
June 25, 2018 02:29AM
Thank you for all the input, i've started working on an ultimaker style, my "plan" is to try keep the design with a foot print under 220*220 and achieve 120-150 build volume, try to make the build volume to size ratio as good as possible
