Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry July 31, 2018 12:57PM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 01, 2018 12:48AM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 01, 2018 01:38AM |
o_lampe
And last but not least, I don't like the Z-axis' 4-motor mechanic.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 01, 2018 11:01AM |
Corner brackets were thicker until I came up with "joint brackets" design in Piper 1 which has moved to Piper 2. All parts are printed without support, there is a need to file off some overhangs in "arches" or cylindrical holes. The very first build I had is printing and traveling for the last 5 months. One of the last trips was in the front seat of Altima, imagine 600mm cube fitting into the front seatQuote
o_lampe
From the looks I'd have made the corner brackets thicker. There are a few parts which look too thin and fragile and hard to print.
Agree 95%, but it is a necessity with moving gantry. Gantry is heavier than the bed so it needs at least 3 points to be stable. One of my Piper 2s has 3 motors but it creeps on the side with a single motor. Currently, I am looking to solve it by working on an open belt driven Z with the single or dual motor. I do not like closed loop belts as they add additional constraints to the design.Quote
o_lampe
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 01, 2018 11:32AM |
Thank you, Nathanael.Quote
NathanaelXYZ
I'm not entirely convinced (yet) on conduit framing, but kudos on the design and execution.
Belts are about 36mm apart, but 18mm from the movement plane they are symmetrical.Quote
NathanaelXYZ
How far apart are the corexy belt planes? I would be concerned about racking forces on the y carriage.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 01, 2018 09:49PM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 01, 2018 11:42PM |
Thank youQuote
Qdeathstar
But, i like the idea. .
Unfortunately you may cut, without special equipment, something with the tolerance of 1-2mm. It is acceptable for this printer, but it would not be acceptable for extrusions fitting.Quote
Qdeathstar
It is as important to cut the pipe precisely as it is to cut extrusion precisely.... .
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 12:53AM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 01:42AM |
90% agree, you will add shipping costs and find that you do not need extrusions or pipes and you are building boxes out of 6mm acrylicQuote
o_lampe
... and machined extrusions suddenly look much more appealing.
Olaf
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 02:14AM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 07:45AM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 09:43AM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 04:38PM |
o_lampe
You save a little money over machined extrusions, but it'll be a hell of a time to align the frame and it'll cost you more when you have to buy special measurment tools.
You only have to buy the tools once and making a series production would eventually even out the bill. But series production of printed parts, were some parts need filing is no fun. Add the extra working hours to the bill and machined extrusions suddenly look much more appealing.
-only my 2 cent-
Olaf
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 09:39PM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 09:42PM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 02, 2018 11:07PM |
piper3d
What artifacts in the print should I be looking for to see racking force intrusion? If this is uneven layers than the only uneven layers I saw on this printer were coming from Z wobbling.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 03, 2018 12:19AM |
NathanaelXYZ
I was imprecise in my comment-- I am imagining twisting forces around the x-axis that would skew the parallel x-rods out of plane with each other.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 03, 2018 01:02AM |
ruyvieira
o_lampe
-only my 2 cent-
Olaf
Pardon my ignorance, but they actually sell machined extrusions? Regular extrusions, but machined to have flat surfaces?
I agree. It looks better than the render. And the locking parts now take care off the layerseperation issue.Quote
Oth, after watching the video, it looks beefy. And you could make it BIG very easily.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 04, 2018 03:35AM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 04, 2018 12:30PM |
o_lampe
I don't fully agree with the statement' moved wires will eventually break' from the video.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 05, 2018 06:12PM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 07, 2018 03:28PM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 11, 2018 03:05PM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 11, 2018 03:18PM |
piper3d
Nathanael, Thank you for the idea.Quote
NathanaelXYZ
If the four motors are controlled independently, then the system actually has the benefit of being able to de-rack the gantry automatically based on z-probing.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 11, 2018 04:20PM |
Your statement is a good but unreachable goal. If you move your machine, no matter how good and rigid it is, you do. My friend is building industrial 3, 5, and 8 cubic meters printers from all the best components and huge extrusions with stress analysis and so on, imagine of moving that monster few inches, you will need to tune it again. Your best design will meet reality and 1 loose bolt may influence your bed positioning. How many recalls cars have? How many maintenance cycles they are going through? And cars are designed by the best engineers.Quote
MKSA
built with the proper components, you don't even need z-probing/auto bed leveling.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 12, 2018 02:12AM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 12, 2018 02:41AM |
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 12, 2018 05:10AM |
piper3d
MKSA
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 12, 2018 08:35AM |
MKSA
The advantage of having only one motor is that you don't need to "de-rack" and provided your machine is of a good design, rigid, properly constrained, accounts for thermal expansion, built with the proper components, you don't even need z-probing/auto bed leveling.
Re: Presenting Piper 2 - CoreXY on EMT conduit frame Single Dual extruder moving gantry August 12, 2018 08:41AM |
