Very Large Cable Driven CoreXY Mechanism
Re: Very Large Cable Driven CoreXY Mechanism
September 03, 2018 03:35AM
the_digital_dentist
I'm planning on using fixed red and blue LEDs because I don't want changing colors and flashing lights to distract attention from the patterns in the sand.
My calculations indicate that a single 50 lb bag of baking soda should cover the table to 1/2" deep. I'll be picking the stuff up at Harbor Freight Tools tomorrow if they have any in stock. I have a 25% off coupon, so $30 will buy the bag.
Please show your calculation smiling smiley
Nice machine BTW, and no need for kids anymore to enjoy drawings on sand !
Edited 1 time(s). Last edit at 09/03/2018 03:37AM by MKSA.
"A comical prototype doesn't mean a dumb idea is possible" (Thunderf00t)
September 04, 2018 11:06PM
It turns out, about 25 lbs of media is sufficient: [vimeo.com]
I need to optimize depth and speed/acceleration.
September 05, 2018 01:11AM
Might be cool to use a nanodots gyro (spinning magnetic orb) instead of the solid ball, might have a smoother motion, or not....
VDX
September 05, 2018 02:45AM
... I was thinking of an "inverted" design in the style of e-paper.
The table is then a flat box, filled with a tinted fluid and floating white plastic microspheres.
If all the particles are spread evenly under the top plate, it looks bright.
Now a moving ball underneath (maybe floating too?) will plow through the microspheres, push them aside and leave a dark (or coloured, if other dye than black) trail ...
Viktor
September 07, 2018 11:36PM
I generated some patterns today and did some speed and acceleration testing. I was very pleasantly surprised to find that the whole thing works fine at acceleration of 1000 mm/sec^2 and speed of 500 mm/sec:
[vimeo.com]
[vimeo.com]
September 08, 2018 02:41AM
It really looks great!
What causes the pauses at the corners? Is jerk setting too low or does the magnet move but it takes a while for the ball to follow? ( square mag/round ball issue we discussed earlier )
edit: I didn't watch the first test... video before, but the pulsing movement seems to be related to unfocussed mag-forces?
Edited 1 time(s). Last edit at 09/08/2018 03:03AM by o_lampe.
September 08, 2018 08:27AM
I don't think the shape of the magnet is affecting the motion. I'm pretty sure I set the junction deviation to zero so the ball stops at the end of every straight segment. When I ran the ball on the table without sand at 200 mm/sec with acceleration turned up the magnet would lose the ball on direction changes. I think that was due to the ball's momentum. That's when I turned the junction deviation to zero to counter that. With the sand providing damping to the motion, the momentum should be less of a problem, so I can probably turn the junction deviation up a bit.
I think the jerky motion at low speed is related to the resistance the sand presents to the ball. At low speed, the sand behaves like a thick liquid and presents a large resistance to motion. When I watch the ball moving at high speeds there is a wave in the sand ahead of the ball where the sand is thrown forward and to the sides. I think the churning that is going on in front of the ball reduces the resistance to the motion. Sort of like the opposite of a classic non Newtonian fluid. At higher speeds, the sand, once started moving out of the ball's way, pushes sand in front of it and essentially "liquefies" it so the resistance to the motion is lower and the ball moves more smoothly. I think.
September 10, 2018 09:08PM
Looks awesome!
You got a shaker to "reset" between prints?
September 11, 2018 09:05AM
When one pattern overwrites another there are always some remnants of the previous pattern remaining that lend some extra character to the current pattern. Even if you see the same pattern repeated multiple times, it will usually look different each time because the pattern before it was probably different. I put the sequences together in a pseudo random way- I generated a bunch of patterns (tedious), then strung them together so that where one pattern ends, the next one starts (also tedious). Most of it looks pretty good, but there are some patterns that just don't work well in sequence together.
I do have some "wipes" made by spiraling the ball, or running it in a zigzag pattern like the first layer of a 3D print, but they always leave lines in the background. I run a wipe every 10 or 12 patterns. I left the machine running overnight and found that the sequence on the SD card runs for over 24 hours. I also found that when you let the machine run that long it tends to push the sand out to the perimeter of the table, though that may be controllable by running approximately equal numbers of patterns that spiral inward and outward. Today's project is to make a tool to spread the sand back out evenly. I'm thinking of a comb that is manually dragged through the sand a few times. The comb will be the width of the table and have discs on the ends that will set the depth of the sand.
I've noticed that with patterns that bring the lines close together, the large ball and relatively coarse sand I'm using tends to wipe out the lines completely. I might be able to get it to erase to a smooth surface by simply running parallel lines close together.
Edited 1 time(s). Last edit at 09/11/2018 09:12AM by the_digital_dentist.
September 11, 2018 10:07AM
Very nice machine. You could add a "tool changer" or a "ball changer" so you may draw with different ball sizes or make "wiping tool" a cylinder rolling from one side to another to wipe picture.
September 11, 2018 11:07AM
I may add ball changing- that's super easy- just a few gcode commands to drop one ball and pick up another...
September 17, 2018 01:51PM
My very large corexy mechanism now has stacked belts. Too much wear on the belts with the single level and twists. I also installed some red and blue LED strips to light it up, powered via buck converters that allow me to adjust the relative brightness of the lights. It is now running pretty well and I'm moving on to try some other pattern generating ideas.
[vimeo.com]
September 18, 2018 12:40AM
It'll be THE eyecatcher on the Makerfair! thumbs up
Would you say NEMA 17 would've worked too at these speeds?
September 18, 2018 09:11AM
I think NEMA-17 motors would work, and probably quieter too. I don't think the load is very large- the mechanism moves easily, and the magnet manages to hang onto the ball even as it is dragged through the sand, so it can't be too much of a load. The moving masses are pretty low, too. When I get a couple spare NEMA-17 motors I'll try it out.
I didn't design the mechanism to maximize the printed area- it was mostly designed to be fast/easy to build. I'm looking at a redesign that will use more of the table for the drawings.
October 26, 2018 01:57AM
Anything to report after the Makerfair?
October 26, 2018 07:15PM
The machine worked fine for the Faire, but close inspection finds that the magnet carriage is wearing out where it rubs against the X axis tube. The tube is powder coated aluminum and it seems that the spring that pushes the magnet against the table is contributing to the wear. The magnet sliding against the table generates very fine wood dust that accumulates on top of the X axis tube and may also be contributing to the wear.
I'm looking at a redesign that will include a UHMW or teflon bearing to reduce wear, as well as sealing the wood with polyurethane, and making a UHMW shoe for the magnet to minimize dust production. Also looking into replacing the NEMA-23 motors with NEMA-17 motors to reduce noise, and maybe putting in a Duet or other controller with TMC high microstepping drivers to further reduce noise. It may be possible to put the magnet directly over the X axis tube instead of off to one side, The tube is 16 mm square and the magnet is a 1" cube, and the frame is 45 mm square t-slot, so I should have barely enough room to do that. I could replace the tube with something a little flatter to gain a little more room to add bearings.
At the Faire I could not get Mike Dubno's RPi firmware running so I just ran from patterns stored on the SD card. I was at the space last night and tried the RPi again and it worked perfectly as soon as I hooked it up. Hmmmm. The RPi talks to the smoothieboard controller via USB.
November 03, 2018 11:50PM
A new update- I redesigned and fabricated a new magnet carriage with UHMW bearings. Hopefully it won't wear like the ABS did. The new carriage body is a piece of 1" square aluminum tubing with a few slots milled into it to mount the bearings and attach the belts. I was lucky and the belt attachments are almost exactly where they need to be to keep the belts parallel to the X axis guide tube.
[vimeo.com]
Blog post with some deets...
Edited 1 time(s). Last edit at 11/03/2018 11:55PM by the_digital_dentist.
November 09, 2018 02:44PM
An alternative use for the sand table- entertaining cats...
November 12, 2018 02:11AM
the_digital_dentist
No kidding, I think there is a market for this. Print a mouse to put on the ball.
November 12, 2018 01:19PM
Could also work as an air hockey robot
November 12, 2018 01:53PM
ruyvieira
I think it's a little too slow for that. The fastest I've been able to run it is about 700 mm/sec. I think it's set to 300 mm/sec in the video.
November 12, 2018 04:39PM
the_digital_dentist
ruyvieira
That's very easy to solve, heh
Just not cheap
Someone else did using a regular Ramps and a webcam for computer vision
