Presenting the NFAN CoreXY 3D printer September 11, 2018 06:34PM |
There are a few things that didn't work based on my design:
What worked very well in my design:|
Re: Presenting the NFAN CoreXY 3D printer September 17, 2018 04:20PM |
imqqmi
Overall the bed is now within 0.15mm level. It's hardly ideal but it'll have to do for now. If you have any tips where I can source an aluminium tooling plate and fitting silicone heating I'd greatly appreciate it! I like the setup of digital_dentist a lot, I think that's the way to go. I might have a look into the kinetic mounting method.
Re: Presenting the NFAN CoreXY 3D printer September 18, 2018 03:04AM |
Re: Presenting the NFAN CoreXY 3D printer September 18, 2018 07:47PM |
Re: Presenting the NFAN CoreXY 3D printer September 20, 2018 06:04PM |
Re: Presenting the NFAN CoreXY 3D printer September 23, 2018 08:41AM |
Re: Presenting the NFAN CoreXY 3D printer September 24, 2018 05:22PM |
Re: Presenting the NFAN CoreXY 3D printer November 15, 2018 12:52PM |
Re: Presenting the NFAN CoreXY 3D printer November 18, 2018 01:02PM |
Re: Presenting the NFAN CoreXY 3D printer November 18, 2018 01:25PM |
imqqmi
Another issue was with setting the Z offset. I've set my homing endstop switch 23.9mm above the nozzle. This means that if I leave the print head above the bed and home it would crash the nozzle into the bed (not a problem, I home the x and y first, which moves the nozzle off the bed). It doesn't appear to be possible to set an offset for the z axis. The x and y M208 worked well, I set the minima to negative values. I also tried tool offset G10 but didn't make a change either, at least not without starting an actual print. When moving the head manually to Z0 it didn't move the nozzle to bed level.
imqqmi
The default motor current was way too high for my high torque nema23 motors, at 800mA. It seems strange somehow that 3A motors should need just 200mA that I use now. I can hardly force the motor to skip by holding the x carriage. The printer moves around on the desk instead of skipping steps
imqqmi
It got at -100 degrees in 5 seconds. I thought it was due to the reversed polarity but it appears that the 0.5 power factor isn't respected. It's putting the full 24V on the 12V heater cartridge.
Re: Presenting the NFAN CoreXY 3D printer November 18, 2018 02:52PM |
Re: Presenting the NFAN CoreXY 3D printer November 18, 2018 03:53PM |
Re: Presenting the NFAN CoreXY 3D printer November 19, 2018 11:34AM |
It still heats up very quickly but overshoots only 8 degrees now. I'll do an autotune soon, to see if that will help reducing it a little more. This effect is also this strong probably because I added an e3d sock to the heater block, reducing the amount of heat it can dissipate.
The nasty resonance at about 50-70mm/s is gone. This also translated in less artifacts on the outer perimeters.
Re: Presenting the NFAN CoreXY 3D printer November 30, 2018 12:32PM |
Re: Presenting the NFAN CoreXY 3D printer November 30, 2018 01:59PM |
imqqmi
Due to the nature of corexy it can do some weird motions like this, stair casing etc.
Re: Presenting the NFAN CoreXY 3D printer November 30, 2018 02:56PM |
Re: Presenting the NFAN CoreXY 3D printer December 01, 2018 12:23PM |
Re: Presenting the NFAN CoreXY 3D printer December 01, 2018 09:05PM |
Re: Presenting the NFAN CoreXY 3D printer December 01, 2018 09:38PM |
Re: Presenting the NFAN CoreXY 3D printer December 06, 2018 01:07PM |
I guess if one motor is stalling or if a coil gets disconnected somehow the diagonal motion and back and forth motion of the other could cause this. That's my thinking anywayQuote
the_digital_dentist
imqqmi
What is in the nature of corexy that can cause stair-stepping?
Re: Presenting the NFAN CoreXY 3D printer December 06, 2018 01:08PM |
I guess you're right. It just seems it's completely gone crazy when it does it.Quote
the_digital_dentist
I guess it could do that if one of the motors skipped steps, then stepped, then skipped steps, etc. I'm not sure what would cause it to do that, but it looks like it happened in the photo you posted.
Re: Presenting the NFAN CoreXY 3D printer March 27, 2019 01:16PM |
Re: Presenting the NFAN CoreXY 3D printer March 27, 2019 02:20PM |
Re: Presenting the NFAN CoreXY 3D printer April 13, 2019 03:42PM |
Re: Presenting the NFAN CoreXY 3D printer April 13, 2019 04:54PM |
Re: Presenting the NFAN CoreXY 3D printer April 13, 2019 05:22PM |
. I should shoot some new footage.
