Introducing myself and some cuestions about bed design in CoreXY February 12, 2019 07:33AM |
Re: Introducing myself and some cuestions about ned design in CoreXY February 12, 2019 08:48AM |
Re: Introducing myself and some cuestions about bed design in CoreXY February 12, 2019 11:53AM |
Re: Introducing myself and some cuestions about bed design in CoreXY February 12, 2019 02:35PM |
the_digital_dentist
One screw located far from the linear guides might be a problem because the spacing between the screw and the bearing blocks acts as a lever to tilt the bed. That will cause the bed to rock on the bearing blocks as the bed moves up and down. Lifting should be done as close to the bearing blocks as possible. If you want to use one motor only, use two screws located next to the bearing blocks and belt it all together.
Re: Introducing myself and some cuestions about bed design in CoreXY February 12, 2019 04:16PM |
Re: Introducing myself and some cuestions about bed design in CoreXY February 13, 2019 02:59AM |
Re: Introducing myself and some cuestions about bed design in CoreXY February 13, 2019 03:36AM |
dc42
You can resync multiple leadscrews automatically if they are driven from separate drivers and you have firmware that supports it. There are two ways of doing it. One is to use the Z probe to measure how out of level the bed is. The other is to use a separate endstop switch for each motor.
Re: Introducing myself and some cuestions about bed design in CoreXY February 13, 2019 05:54AM |
Re: Introducing myself and some cuestions about bed design in CoreXY February 13, 2019 06:05AM |
