Evaluating Craftbot 3 Design
April 05, 2019 03:25AM
Looking to build a niche machine for printing orthopedic devices (mostly prosthetic sockets) and looking into motion systems.
What do you all think about the new Craftbot 3 gantry system?
It is almost like a Cartesian & H-bot hybrid, so shorter belts, no stacked or crossed belts, and a mechanically (albeit not so much w/ firmware) simple IDEX implementation w/ no moving motors (other than extruders). Seems like it would be easy to keep the non-extruding motors out of the heat zone for a heated build area if necessary as well.
Leaning going this direction (probably with only 1 Y motor like FFCP/Replicator) and willing to fight the firmware battles to end up with a more straightforward alternative to the CoreXYU or heavier cartesian IDEX in the long run.
Edited 1 time(s). Last edit at 04/05/2019 03:27AM by ChayDuuLetDuu.
Re: Evaluating Craftbot 3 Design
April 06, 2019 12:38AM
That was just looked like H-bot.The X-axis should use dual X motors for longer belt to reduced tilt.
Edited 1 time(s). Last edit at 04/06/2019 12:46AM by datesheet.
April 06, 2019 03:30AM
ChayDuuLetDuu
RepRapFirmware will support that configuration without you even needing to recompile it. The standard binaries support any kinematics in which the motion of each axis is a linear combination of motor movements (as well as several nonlinear kinematics). You specify the motion coefficients in a command in the config.g file on the SD card.
The extruder motors in that picture look unnecessarily heavy, even if using a Bondtech or similar extruder with only 3:1 gearing. With higher gearing you could use pancake motors or Nema 14 motors.
