CoreXY 2:1 belt ratio double torque and resolution ? April 16, 2019 04:48AM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 16, 2019 06:56AM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 16, 2019 07:04AM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 16, 2019 03:11PM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 16, 2019 04:26PM |
Pippy
........................Seems a waste to have the ability to go fast with normal setup (say 250mm/sec with 20 tooth pulleys) and not really be able to use it.......................,
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 02:04AM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 03:08AM |
dc42
An easier way to increase resolution (if you need to) is to use 0.9deg motors and 16-tooth motor pulleys.
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 03:11AM |
Pippy
I'm running the motors at 4 microstepping rather than the usual 16, as you get quite a bit more torque at lower microstepping it seems
Pippy
plus it prevents Marlin from switching to double stepping,
Pippy
and the noise level is not really any different to 16 microstepping when using TMC drivers.
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 03:36AM |
dc42
Pippy
That's a myth. Going from full stepping to half stepping reduces torque (and motor heating). Increasing microstepping further doesn't reduce torque.
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 05:54AM |
Pippy
V-slots and wheels sure does simplify a printers mechanics, and doesn't appear to affect resolution/accuracy etc over other methods, I guess ?
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 07:03AM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 07:40AM |
deckingman
At the last count, my printer which now has 3 CoreXY gantries (one for the hot end, one for the 5 extruders and a third which acts as a load balancing/ force cancelling gantry) uses 60 sets of wheels which is 2 to 3 times what many people spend on a complete printer.
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 07:42AM |
the_digital_dentist
If you really want high resolution, and have deep pockets, you could use 5 phase steppers. They usually come in either 500 or 1000 full steps per rev. You can sometimes find surplus motors with matching drivers on ebay for <$100. You have to be careful if you get motors and drivers from different sources. Some motors are wired for "pentagon" drive, and some for star drive. The drivers have to match the motor type. Not all the drivers can do microstepping, but it looks like most will do 1/2 steps.
Try this for the search: 5 phase stepper motor -4 phase -two phase -3phase -2 phase
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 08:29AM |
dc42
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 10:57AM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 11:12AM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 17, 2019 03:46PM |
Pippy
I've been testing various combinations of microstepping and motor current etc, the one thing I found was motor stalling with 16 microstepping as compared to 4 microstepping at the same high speed setting, I had to go from 250mm/s (with 2:1 belt ratio) with 4 microstepping down to approx 220mm/s when using 16 microstepping to prevent motor stall.
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 18, 2019 11:58AM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 18, 2019 12:20PM |
dc42
Pippy
That's probably because your electronics/firmware combination can't generate smooth step pulse trains at high speeds when using x16 microstepping. Smooth step pulse trains are especially important at high speeds, particularly if you have microstep interpolation enabled in the drivers. (That's one of the reasons why we stopped using double etc. stepping in RepRapFirmware. Servo drives hate non-smooth step pulse trains even more.)
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 18, 2019 12:32PM |
obelisk79
Couldn't you just get some inexpensive brass gears and do the same thing that way with less cost and complexity?
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 18, 2019 12:51PM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 18, 2019 01:24PM |
obelisk79
I'm just here to engage in a discussion as an enthusiast hoping to learn more and share ideas. I'm not here to say your design is dumb or pointless.
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 18, 2019 03:49PM |
Pippy
dc42
Pippy
But that's just not the case, from testing here.
Though yes the 8-bit board is limited due to lack of processing speed.
We get 400mm/s WITH the 2:1 belt reduction on the 32-bit board (16 micro stepping), 20 tooth drive pulley, clean stepper pulse train (on the scope), TMC2208 at 1amp, 256 interpolation enabled, 24V.
Their is a notable torque difference between 16 micro stepping and 4 micro stepping (at full motor speed), We're certainly getting more torque with 4 micro stepping, it takes more effort to stall the motors at 4 than it does at 16.
The TMC2208's are configured to switch from StealthChop2 to SpreadCycle at 1/3 the top speed (400mm/s).
We're only going from what we're finding here. Try it ?
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 20, 2019 08:52PM |
Pippy
dc42
Moving to 16 tooth drive pulley would be nice because that produces 0.02mm per step rather than 0.025mm per step .. nice to have more rounded numbers, not that it makes any difference at that level with home built 3D printing really.
The reason for me was mainly to reduce motor load. The added benefit of torque, acceleration and resolution is there if ever it was required.
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 20, 2019 11:08PM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 20, 2019 11:48PM |
piper3d
It is niether 0.02 nor 0.08.Quote
shortyski13
How do you get .02mm? I get .08. Isn't it 2mmx16x(.9/360)
20 teeth x 2mm x 1.8/360 x 1/16= 0.0125
16 teeth x 2mm x 1.8/360 x 1/16= 0.01
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 21, 2019 01:19AM |
So you have effective microstepping of 1/8th.Quote
Pippy
We're not using 16 microstepping. Plus we're using 2:1 belt reduction - reduces the load on the motor and the belt.
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 21, 2019 12:15PM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 21, 2019 10:56PM |
Re: CoreXY 2:1 belt ratio double torque and resolution ? April 23, 2019 10:26AM |
