Repsis: A 3D printer with a heated chamber i made May 01, 2019 12:56PM |
Re: Repsis: A 3D printer with a heated chamber i made May 02, 2019 07:02PM |
Re: Repsis: A 3D printer with a heated chamber i made May 03, 2019 02:03AM |
Re: Repsis: A 3D printer with a heated chamber i made May 03, 2019 11:00AM |
Re: Repsis: A 3D printer with a heated chamber i made May 09, 2019 06:55PM |
the_digital_dentist
It looks like a really solid, well planned build.
Don't those multiple blowers ruin ABS prints, or is the chamber so hot it doesn't cause a problem? How hot does the chamber get when you're printing?
Will the blower motors' built-in drivers tolerate the heat in the chamber?
Re: Repsis: A 3D printer with a heated chamber i made May 12, 2019 04:29PM |
NitroFreak
the_digital_dentist
If you can get the blown air so hot that it is between the HDT and the Tg, then that is the ideal scenario because it prints the fresh layers, cools them down quickly to the Tg but not so low that it starts to solidify completely and warp.
I use the same concept with a 2500w heating element and a huge fan to "cool" PPSU prints to 212°C. No warping whatsoever.
The concept is not really new, every stratasys machine uses it.
The reason PLA works so well with blowing cold air over it is that room temperature air is close enough to PLA`s Tg that it does not cause warping.
Re: Repsis: A 3D printer with a heated chamber i made May 12, 2019 04:31PM |
Re: Repsis: A 3D printer with a heated chamber i made October 14, 2019 04:43PM |
