Z axis help
Posted by drthomasw3
Z axis help
August 29, 2019 11:59AM
I am controlling a Tronxy X5SA with a Duet 2 WiFi and BLTouch. x and y are set forward with z and the extruder set to backward. all axis and the extruder respond correctly to direction/distance commands from the panel. z+ inputs result in the bed moving down or away from the print head.all axis including the z home correctly. When I print the z moves in the wrong direction. I checked the G code and the z is to move + or.2mm down each layer. Instead, the bed is moving into the print head. Any suggestions?
Re: Z axis help
August 29, 2019 03:40PM
After homing all axes, does G1 Z0 leave the nozzle just touching the bed?
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
Re: Z axis help
August 29, 2019 07:24PM
Yes
Re: Z axis help
August 29, 2019 07:27PM
Sorry no it almost touches then drops down 5mm
Re: Z axis help
August 30, 2019 02:34PM
I suggest you ask for assistance at [forum.duet3d.com]. Attach your config.g and homing files to your post, and state which firmware version you are using.
Edited 1 time(s). Last edit at 08/30/2019 02:35PM by dc42.
Re: Z axis help
August 30, 2019 04:18PM
Did that thanks for the help.
Tom
