CoreXY extra endstop on the Z
Posted by Dunston-UK
September 04, 2019 06:25PM
Tronxy x5 330 x 300 x 400
DuetWiFi
BLTouch V1
HI
I want to use an extra endstop on the Z alongside the BLTouch, to stop the bed hitting the top of the steppers when it moves down. I have it working correctly for the homing using the BLT, but I can't work out how to do the extra endstop, I know it has to be on the spare extruder on the DuetWiFi, any help on a sample config would be great. I have read the doku on the Duet website but I have either missed it or misunderstood it.
Thanks
Re: CoreXY extra endstop on the Z
September 05, 2019 05:13AM
Assuming the BLTouch is connected to the Z probe input, then you can still connect your extra switch to the Z endstop input.
How do you want to use the switch: to home to max Z (bed all the way down), or to cause an emergency stop when it is triggered?
Large delta printer [miscsolutions.wordpress.com], Robotdigg SCARA printer, Crane Quad and Ormerod
September 09, 2019 10:00PM
Hi dc42
I wanted it to be for the home to max ie: when the bed is all the way down.
My BLTouch is connected as the Z probe.
; Endstops
M574 X1 Y1 S0 ; Set active high endstops
; Z-Probe
M574 Z1 S2 ; Set endstops controlled by probe
M558 P9 H5 F120 T6000 X0 Y0 Z1 ; Set Z probe type to bltouch and the dive height + speeds
G31 P500 X0 Y15 Z2.5 ; Set Z probe trigger value, offset and trigger height
M557 X15:300 Y15:300 S30 ; Define mesh grid
M307 H3 A-1 C-1 D-1 ; Disable heater on PWM channel for BLTouch
The M574 is set to Z1 though what would I have to change there.
dc42
Edited 1 time(s). Last edit at 09/09/2019 10:04PM by Dunston-UK.
September 10, 2019 03:30AM
Use M574 Z2 S1 (or S0 if your endstop is active high or an NO switch) and search the Duet3D wiki page for "homing z".
Edited 1 time(s). Last edit at 09/10/2019 03:31AM by dc42.
September 10, 2019 03:46AM
Thank you dc42
