Weird CoreXY behavior![]() October 12, 2019 07:32PM |
Re: Weird CoreXY behavior![]() October 12, 2019 09:48PM |
Re: Weird CoreXY behavior![]() October 13, 2019 05:58AM |
Re: Weird CoreXY behavior![]() October 13, 2019 08:10AM |
Re: Weird CoreXY behavior![]() October 13, 2019 09:28AM |
Re: Weird CoreXY behavior![]() October 13, 2019 10:13AM |
Re: Weird CoreXY behavior![]() October 13, 2019 10:46AM |
Re: Weird CoreXY behavior![]() October 13, 2019 01:59PM |
Re: Weird CoreXY behavior![]() October 13, 2019 06:11PM |
Re: Weird CoreXY behavior![]() October 14, 2019 08:15AM |
Re: Weird CoreXY behavior![]() October 14, 2019 08:35AM |
FlyingRobot
There is sort of a linear rail under; it is actually two pieces of plastic stuck on the wood to reduce friction, I also drenched it with oil to make it slide better. No worries, real linear rail on the way! I also did as you said, placing all the belts attachments at the same level.
Finally, I solved my weird problem about the movement! It was two motor pins on the board that were shorted together; I just had to get them away from each other and it worked!
[drive.google.com]
Thank you so much for your time!
Re: Weird CoreXY behavior![]() October 14, 2019 11:03AM |
