Backlash Nuts, face up or down October 17, 2019 07:42AM |
Re: Backlash Nuts, face up or down October 17, 2019 10:48AM |
Re: Backlash Nuts, face up or down October 17, 2019 10:57AM |
the_digital_dentist
It don't think it matters which way you put the nuts, but...
When you're moving a load horizontally with a screw, when the screw reverses direction you can get backlash because there is a gap between the screw and nut threads. An antibacklash nut uses a spring to keep the threads engaged in both directions by pushing two nuts against the screw threads (which increases friction).
When you're lifting a load against gravity, no matter which way the screw turns, gravity is pulling down on the load and keeping the screw and nut threads engaged. As long as the mechanism drops freely under gravity (without the screws connected), there's no need for antibacklash nuts on a vertical screw drive. If the mechanism doesn't drop freely under gravity, the guide rails may be out of alignment and that should be corrected.
Re: Backlash Nuts, face up or down October 18, 2019 02:57AM |
Re: Backlash Nuts, face up or down October 18, 2019 03:29AM |
Re: Backlash Nuts, face up or down October 18, 2019 04:45PM |
MKSA
Note, nuts precision is the same, made with the same tooling !!!!! Statement above irrelevant).
