Hypercube - Uneven Layer Lines / Z axis banding October 21, 2019 07:04PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 23, 2019 06:27AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 23, 2019 12:44PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 23, 2019 12:49PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 24, 2019 04:47AM |
Mogal
Oh, and watch the belt around the pulleys. If there is any misalignment in the belts, you might see the belts flop back and forth on the pulley
as it tried to climb up/down and off the pulley...
- This mostly occurs on the stepper pulley as the mount is not ridged enough and causes a deflection in the belts.
Mogal's Belt deflection on Hypercube
Re: Hypercube - Uneven Layer Lines / Z axis banding October 24, 2019 10:02AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 25, 2019 02:58PM |
Just rechecked: e-steps are fine; to verify flow rate I printed a 0.8mm thick cube and it measured 0.8mm... I never did a flow rate check so I'm not sure if this is the best option.Quote
AmyTheBun
I'd start by making sure your e-steps and flow rate are correct.
There isn't any play (that I can notice), either on the hotend, x axis carriage, y axis, z axis, bed. For all I can remember to check, nothing appears to have play.Quote
AmyTheBun
then I'd check if the hotend has any play
then I'd check if the z axis or the bearings/y axis or literally anything has play to it
I don't have any binding on the Z axis. It can move freely. The lead screw appears to be straight and isn't "dancing" while the motor is spinning.Quote
AmyTheBun
then I'd check if the z axis has any binding and does move freely.
Then I'd wait for more answers
Are those the usual nuts for the T8 threads? Can you direct me when to find them?Quote
AmyTheBun
I use acetal POM trapozoidal nuts and they're fantastic. they helped increase the print quality of my anycubic i3 mega-s so much! but yeah. if you don't wanna go and buy them you can print them in pla and they work surprisingly well. the only issue being pla melts at a relatively low temperature and the nut is printed in a way that the z is where the load is on. but again they're not that expensive I think? I forgot how much mine cost
I do have all axis well lubricated.Quote
AmyTheBun
also I assume your axis are all well lubricated.
also are your belts maybe gettnig worn or not aligned? In a corexy the belt system is a huge fuss. one tiny mistake and you get horribly irregular layers due the changing tension. one of the reasons I don't like corexy as great as it is!
EDIT: I just noticed you have the toothed side of the belt on smooth idlers (beaings) I heard that's not a good idea whatsoever. you could either twist the belt(not sure whatsoever on how it affects it. but only do it on the long side of each stepper) or switch to a toothed idler
I just checked my rails and they are smooth, I didn't find any tracks caused by the ball bearings. I also don't have any play in them, but sometimes they make a "rattling" sound when moving. Should I replace them?Quote
Mogal
Maybe unrelated, but I had a similar issue. When I first got the printer working and tuned, it was producing amazing prints...
I found my prints slowly degrading in quality... After watching the printer for awhile, I could see the print head 'Float'
(I could actually see the print head wobble) as it was travelling back and forth... took a closer look at the bearings and rails
to find that the bearings had carved a track through the rail. (some of the balls where stuck in the bearing digging a trench in the rails)
Its hard to take a good picture of the groove, but its significant enough to cause quality issues.
Mogal
My belts do tilt a bit. Nowhere near as much as on the video, but I can see that the motor axle isn't perfectly vertical (the entire motor isn't, the axle relatively to the motor is fine).Quote
the_digital_dentist
Belts should not tilt like the ones in the video- there is something seriously wrong with the rest of the mechanism. Pulleys must be mounted on vertical axles that must stay vertical when tension is applied to the belts. Belts should remain at one level throughout their travel- don't vertically cross corexy belts- there's no need for it and it will cause problems.
There are about 1000 different problems that can cause rough Z axis print quality. The type of Z axis problem you're seeing is measured in microns. It is difficult to see that little wiggle in the hot-end/extruder carriage. It may be due to slop in the XY mechanism, the Z mechanism, or both. Troubleshooting is a combo of careful observation and logical thinking. It used to work fine but print quality has degraded. That rules out the controller which has remained constant. Since quality has degraded, it indicates something is wearing out or getting loose compared to when the machine was first built. Hypercubes have a lot of plastic motor and pulley mounts- maybe one or more has cracked or deformed under the strain of heat and belt tension. The OP said that one of the belts had a cut in it- that shouldn't happen, so I'd look carefully around that belt's part of the mechanism. Make sure everything is tight and lubricate bearings.
The Z screws don't move much, so they aren't likely to wear out in your lifetime unless you've got the mechanism so poorly aligned that it takes a lot of force to turn them.
Brass nozzles can wear out, especially if you print with glow-in-the -dark, glass, carbon, or metal particle loaded filaments.
Mogal: the grooves in the guide rails are there because you didn't use hardened guide rails. Whenever you use linear bearings on guide rails, the rails must be the hardened type. When you buy the rails, if they don't say they are hardened, they aren't. Hardened rails cost a little more than the other type. You can tell if rails are hardened by trying to scratch them with a file. A file won't leave more than a barely visible scratch on a hardened rail, and will happily cut into an unhardened rail.
Belt teeth on smooth pulleys is OK. The biggest problem is a zipping noise it causes when you run the mechanism really fast (like 500 mm/sec, which you're unlikely to use in a 3D printer).
Re: Hypercube - Uneven Layer Lines / Z axis banding October 26, 2019 03:42PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 26, 2019 04:03PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 26, 2019 05:16PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 26, 2019 07:02PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 26, 2019 09:24PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 27, 2019 07:35AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 27, 2019 08:59AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 27, 2019 12:54PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 28, 2019 06:40AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 28, 2019 06:47AM |
Mogal
I really like DD mount that he made. Lots of rigidity there. But that wont directly plug in to the hypercube design.
The one I posted looks like the motor actually rests on that inside wall. (ie: no deflection)
Re: Hypercube - Uneven Layer Lines / Z axis banding October 28, 2019 12:44PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 28, 2019 06:51PM |
That looks a very nice design (and a very nice print!).Quote
the_digital_dentist
The force applied to the motor comes from the pulley on the shaft. All that plastic around the motor body does little to improve overall rigidity of the mount. I would design the mount something like the one on the right:
Here's one I used in my corexy sand table project- no visible flex at all (though I'm sure there must be some):
When I design stuff like this, I place the motor in the CAD file in it's ideal location relative to the frame of the printer, then add in a big rectangular solid on top of the motor, then start cutting away anything that interferes with the belt and pulley, and finally the frame. Add tangs to fit in the frame slots and screw holes for the motor and the mount and you're done.
Mogal
Start looking through thingiverse (and others) for different designs. Lots out there.
I was using 12mm rods for the z, 10mm for the Y and 8mm for the X.
I'm using some off the shelf parts and some machined Alum. It's still a work in progress...
So far, I'm finding the rails far superior over the rods, but it does seem to be a little more finicky to align.
The rods I had also had a small warp to them...
With the rails, I can straighten them out some when I bolt them down to the extrusions.
AmyTheBun
[www.thingiverse.com]
try this if your motor is tilted
i am making this trying to make the printer a tiny bit better
also this is a sample link. I found it online [www.aliexpress.com]
Mogal
Hard to tell. But I would say there is something loose and/or misaligned.
As the carriage moves one way, the belt moves up, then reverses the opposite direction.
Seems like the XY joiner is higher/lower then the stepper motors and XY idler.
So as the XY joiner moves closer to the stepper, it forces the belt down. then as it moves away, creeps back up...
Make sense?
All the belts have to be on the same plane. And all the pulleys have to be perpendicular (90 degrees) to the belts.
Re: Hypercube - Uneven Layer Lines / Z axis banding October 29, 2019 04:53AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 29, 2019 07:43AM |
AmyTheBun
Mogal
Hey my belts only slide up and down on the motor pulley. and they only tilt very lightly on the xy idlers on the back of my printer. is this a cause for worry? I mean i tried everything and they just don't seem to be fixed. I have no idea where the misalingment is or how to fix the misalingment
EDIT: Sorry for the horrible video quality but I uploaded a few videos
[photos.app.goo.gl]
Re: Hypercube - Uneven Layer Lines / Z axis banding October 30, 2019 06:25AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding October 30, 2019 06:48AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 05, 2019 03:09AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 05, 2019 02:12PM |
AmyTheBun
sadly as someone with a low budget experimenting is not an option for me.
I am thinking of selling the hypercube and buying an artillery sidewinder instead
Re: Hypercube - Uneven Layer Lines / Z axis banding November 05, 2019 03:16PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 05, 2019 03:18PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 05, 2019 04:18PM |
AmyTheBun
also that wasn't very nice some of us just want a 3d printer that works. specially a lot of us don't have time or money to spend on a printer like this. you know how long it takes to try on a new carriage or y carriage! swapping it takes a day!
Re: Hypercube - Uneven Layer Lines / Z axis banding November 07, 2019 06:02PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 07, 2019 10:30PM |
