Re: Hypercube - Uneven Layer Lines / Z axis banding November 08, 2019 02:30AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 08, 2019 11:58AM |
Mogal
AmyTheBun
also that wasn't very nicesome of us just want a 3d printer that works. specially a lot of us don't have time or money to spend on a printer like this. you know how long it takes to try on a new carriage or y carriage! swapping it takes a day!
Sorry, was just suppose to be a reality check... I didn't mean anything bad.
As for time it takes.. uhm, yeah I know all too well how long it takes.
I started with a hypercube. And although its still a core XY, it's by no means a hypercube anymore.
Just like the troubles your having with rigidity, I too was having those issues. Then the rails started to fail.
So over the last 5-6 months, I've been designing and machining the new machine (mostly out of aluminum)
And over the last couple of days, I've been testing and tweaking the machine.
It takes time, but if you take that time, learn the intricacies, you too can have a great quality printer!
Keep it up like you are, and you'll be there in no time! And you'll be thankful you did!
if eel like designing a printer from scratch tbh but that takes money|
Re: Hypercube - Uneven Layer Lines / Z axis banding November 08, 2019 12:02PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 11, 2019 06:46PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 13, 2019 10:20AM |
Mogal
Over all, I'd say your prints are very good.
To improve them? Maybe the extrusion rate, temps, jerk and acceleration settings.
There is a tiny bit of ringing, but it's small and might not be able to get rid of it all.
As for what improved mine? Regidity. Losing the cantilevered bed design.
Tweaking my feeds/speed, extrusion, jerk and excel settings. Making sure the frame is
tight and square. No vibration/rattling. Belts are straight, tight and aligned.
I also placed silicon dampening feet on the frame as well.
I also splurged with 0.9deg steppers and went with a 3:1 z axis with 8mm diam, 2mm lead screws.
Duet 2 Wifi as well. And yes, I spent WAY too much money on this, but it's one of my hobbies,
and I can use the replaced parts for other projects.
If your designing your own parts, it just takes time.
Not much money, unless you change out everything like I did.
i use prusaslicer and design in fusion 360. my flow rate and e-steps are calibrated.
It's a hobby, take your time, enjoy it! Be critical and make awesome prints.
What software are you designing in/slicing with?
have this cube to fix in the meanwhile. but the sk-go sounds so amazing! the print quality they showed and teachingtech showed on youtube were stunning!|
Re: Hypercube - Uneven Layer Lines / Z axis banding November 13, 2019 05:35PM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 14, 2019 05:16AM |
Re: Hypercube - Uneven Layer Lines / Z axis banding November 14, 2019 06:33AM |
AmyTheBun
but i'm not sure if my belts are aligned. and I have no idea on how to fix it considering the hypercube doesn't have any adjustment options..
