Which Kit? Railcore? SecKit? Other? March 06, 2020 04:46PM |
Re: Which Kit? Railcore? SecKit? Other? March 06, 2020 05:55PM |
Re: Which Kit? Railcore? SecKit? Other? March 06, 2020 09:34PM |
Re: Which Kit? Railcore? SecKit? Other? March 07, 2020 12:30AM |
Re: Which Kit? Railcore? SecKit? Other? March 07, 2020 02:10AM |
the_digital_dentist
I posted a CAD model of UMMD and a lot of information about problems and fixes for them. That's what open source is about. I'm surprised anyone tried to commercialize it because it isn't the cheapest way to build a printer, and cheapness seems to be the main driver of printer sales.
Most of the non corexy cartesian mechanisms move the X axis motor along the Y axis. A lot of people worry about the mass that motor adds, but I'm more concerned about having to run a cable to it. It's bad enough you have to run one to the extruder, but running two multiconductor cables to two moving motors is asking for trouble. I'm sure it can be done reliably if you apply enough effort, but it isn't my preference. My older printer, SoM, uses a flex ribbon cable to take all the signals and power to the extruder carriage. It has been working with 100% reliability for about 6 years now. If I could find a cheap source of that type cable and tools to terminate it I'd probably go into business selling it to 3D printer builders. I hate running cables to moving stuff and finally took the X axis endstop switch off the extruder carriage in SoM.
Back to your question. The short answer is no, I don't think there's any special advantage of corexy over any other cartesian (except maybe H-bot) when it comes to print quality when you're printing at "normal" speeds. Just about any mechanism will work fine. Corexy is pretty easy to build well, once you understand how it works.
I don't think much of the mechanical complication that something like a remote-motor extruder adds. The whole point of moving the motor off the extruder is to reduce moving mass so you can theoretically print faster, but in order to make it work they have to gear it down 20:1 and that may limit extrusion speed which will limit print speed anyway. What is the benefit that justifies the added cost and complication?
The Duet people are working on a design that runs power and a serial wire to the extruder and that's it. It'll have a board on the extruder carriage that drives the motor and controls the heater and fans. That will be a real advance over the multipin cabling and connectors that are needed now.
Re: Which Kit? Railcore? SecKit? Other? June 06, 2020 01:44PM |
I'm not a big fan of the Railcore design. Too many printed parts that extend beyond the frame, making it hard to enclose.
The motor mounts look flexible, the pulley mounts don't look very good either. Standing a post with two pulleys up in a piece of printed plastic and putting tension on the belts is likely to cause the plastic to flex and tilt the post.
I'm also not a fan of using multiple Z axis motors. They get out of sync when you cycle power and that tilts the bed so you have to have some sort of scheme to relevel the bed frequently. It looks like the design could easily be modified to use a single Z axis motor.
It's hard to be sure from the CAD model that doesn't show the belts, but it looks like the A and G belt segments will not be parallel to the Y axis guide rails.
Re: Which Kit? Railcore? SecKit? Other? June 06, 2020 04:57PM |
the_digital_dentist
I'm not a big fan of the Railcore design. Too many printed parts that extend beyond the frame, making it hard to enclose. The motor mounts look flexible, the pulley mounts don't look very good either. Standing a post with two pulleys up in a piece of printed plastic and putting tension on the belts is likely to cause the plastic to flex and tilt the post. I'm also not a fan of using multiple Z axis motors. They get out of sync when you cycle power and that tilts the bed so you have to have some sort of scheme to relevel the bed frequently. It looks like the design could easily be modified to use a single Z axis motor. It's hard to be sure from the CAD model that doesn't show the belts, but it looks like the A and G belt segments will not be parallel to the Y axis guide rails.
Re: Which Kit? Railcore? SecKit? Other? June 06, 2020 05:41PM |
Re: Which Kit? Railcore? SecKit? Other? June 07, 2020 10:12AM |
Wescherry
A lot of misinfo on the Railcore from the Dentist.
This re-tramming of the bed happens automatically, doesn't take more than a few seconds and levels the bed better than most can do with manual screws. It also accounts for different thickness springsteel build plates automatically.
Re: Which Kit? Railcore? SecKit? Other? June 07, 2020 02:57PM |
Re: Which Kit? Railcore? SecKit? Other? June 07, 2020 03:08PM |
