I have a G&C CoreXY printer (
Thingiverse) that is working acceptably well, apart from a small number of niggles. If I pay attention to slicing details I can produce a decent print in PLA, PLA+ and ABS. The frame is quite solid, and I am content with the bed and the Z mechanism for the time being. The biggest hurdle is that its CoreXY mechanism is a complete PITA to maintain. I have just had to do some maintenance to the belts and bearings that took me the best part of a day to complete, including the partial disassembly of the frame (the guide rods and belts are within the frame). A lot has to be removed to do any sort of maintenance, which means that all calibration is right out the window when the job is completed. It's also a PITA to get the belt tension correct (something I've posted about recently!).
The printer is now working again, but I am planning a near-future upgrade to a CoreXY mechanism that sits on a plate mounted on top of the frame. Mark Rehort's web page (
Link) shows what I'm considering, preferably using linear guides. Here is the sort of thing I'm looking at:
The designer of the G&C CoreXY printer has designed an all-metal version (
Thingiverse) but I have some reservations about it - getting guides that match the DXF design being one of them.
I have various questions, including:
- What length of rail should I use to cover a bed of 200mm x 200mm? (300mm?)
- What width of rail should I use? The easiest to source come in 9mm, 12mm or 15mm - I guess 15mm is best, but it's also the most expensive!
- If I draw up a DXF file, is water jet cutting the best option for something like 5mm aluminium plate? Is it accurate enough, or should I plan for small-diameter holes and drill out to the target size?
My aim will be to create a CoreXY mechanism off the printer that can be mounted when I'm sure that it's working correctly, with minimum disruption.
All helpful comments and advice gratefully received...
David
