New CoreXY build motor issues August 17, 2020 10:57AM |
Re: New CoreXY build motor issues August 17, 2020 12:43PM |
Admin Registered: 11 years ago Posts: 3,096 |
Re: New CoreXY build motor issues August 17, 2020 01:08PM |
Re: New CoreXY build motor issues August 17, 2020 01:13PM |
Re: New CoreXY build motor issues August 17, 2020 02:51PM |
Re: New CoreXY build motor issues August 17, 2020 06:30PM |
Re: New CoreXY build motor issues August 18, 2020 10:00AM |
Ohmarinus
Would you be able to make a video and some photo's of your build and a video of the binding? It would help a great deal to pinpoint the issue.
Re: New CoreXY build motor issues August 18, 2020 10:09AM |
Re: New CoreXY build motor issues August 18, 2020 10:14AM |
Ohmarinus
Alright, my first advice would be to move the machine through a host program via usb. This makes movement much smoother. It could be too high feedrate or acceleration settings as well. Furthermore you can already see the top belt on the right side of the X-carriage isn't coming straight out of the carriage. Can it be the belt paths aren't straight?
Also indeed sounds like the motors are skipping steps due too too much torque needing to be applied.
Re: New CoreXY build motor issues August 18, 2020 12:41PM |
Re: New CoreXY build motor issues August 18, 2020 12:55PM |
Re: New CoreXY build motor issues August 18, 2020 03:04PM |
Re: New CoreXY build motor issues August 19, 2020 11:33AM |
the_digital_dentist
For testing do whatever you need to get things working. Disconnect the belts and try driving the motors and see if they turn properly. If not, the problem isn't just the load on the motors.
Re: New CoreXY build motor issues August 22, 2020 05:03AM |
Re: New CoreXY build motor issues August 22, 2020 07:41AM |
Re: New CoreXY build motor issues August 23, 2020 02:31AM |
Re: New CoreXY build motor issues August 23, 2020 02:43AM |
Re: New CoreXY build motor issues August 24, 2020 10:48AM |
Re: New CoreXY build motor issues August 24, 2020 10:59AM |
piper3d
Your horizontal belt planes (driving the carriage and Y) are not flat. It means that belt tension will be different for different carriage positions. Most likely belts are jamming pulleys and motors are not able to move. I tried to line planes they maybe influenced by perspective but problem is visible anyway. That left motor is too high and most likely your major problem.
