Port use
RS232 needed for Touch use requires the black cable. Needs a serial port in firmware for it to function.
EXP3-CR10 128x64 graphics mode using 1 10pin plug, firmware needs CR10_STOCKDISPLAY
EXP1-EXP2 128x64 graphics mode using 2 10pin plugs, firmware needs REPRAP_DISCOUNT_FULL_GRAPHIC_SMART_CONTROLLER
BTT TFT35 v3.0 pins
github.com]
LPC1768 serial pins
github.com]
MKS-SGen has no socket designed for the tft
github.com]
Can be made to work on serial port 0 on aux-1. and on J7 as serial port 1 (need to check if 5v has sufficient current to drive this)
MKS-SGEN_L has no socket designed for the tft
github.com]
Can be made to work on serial port 0 on aux-1. Again need to check sufficient 5v current is available.
MKS-SGEN_L-V2 has no socket designed for the tft
github.com]
Can also be made to work on serial port 0 on aux-1. Again need to check sufficient 5v current is available.
Edited 2 time(s). Last edit at 11/30/2020 01:44AM by Dust.
