Belts pitch: 2 or 3 mm ? Your opinion ? January 24, 2021 02:09PM |
really useful writings ): rails, belted/worm gear lifted Z axis , separate Z frame, etc...|
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 06, 2021 01:23AM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 06, 2021 07:59AM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 06, 2021 10:16AM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 06, 2021 03:35PM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 06, 2021 03:49PM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 07, 2021 09:01AM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 07, 2021 10:38AM |
I agree with you. The Prusa calculators helped me to visualise the real difference between 2 and 3mm pitch. It is near nothing in term of accuracy for a tool which extrudes melted plastic.Quote
the_digital_dentist
I don't think 2 or 3 mm pitch makes any difference, especially if it is GT profile
I don't think so : one full turn of a 3mm pitch driving pulley is the same full turn than a 2mm pitch driving pulley of the same diameter: it remains a full turn, and the length of ''moved belt'', is the same. So there is no gain, or loss for speed.Quote
MechaBits
I suppose you get faster with the larger pitch, and a new controller to divide the steps more.
I would be glad if you can point me to a source of Genuine GT2, 2mm pitch, 15mm wide GATES belts.Quote
gmedlicott
(and GT2 2mm can be sourced in 15mm wide as well
Yes you are probably right. But...everything is in the word: ''probably''.Quote
gmedlicott
as the digital dentist mentioned, it probably doesn't have much effect in practice, as there are other larger contributing factors to accuracy
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 07, 2021 11:42AM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 07, 2021 02:44PM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 07, 2021 02:57PM |
MechaBits
in the same way a 5mm lead on a screw would be faster than a 2mm lead
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 07, 2021 03:22PM |
Admin Registered: 18 years ago Posts: 14,184 |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 07, 2021 05:41PM |
Misumi USA has everything to answer this question hereQuote
MechaBits
but I wouldnt know the diam of a 20t gt3
an interesting point: I must to think of it twice, before making the choice of belt widthQuote
leadinglights
Wide belts lever on the shaft more than narrow belts as narrow belts can be set closer to the flange.
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 08, 2021 01:27AM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 08, 2021 03:41AM |
Re: Belts pitch: 2 or 3 mm ? Your opinion ? February 08, 2021 06:11AM |
Specification Classical Tooth profile T5 Belt width 6mm Number of teeth on large pulley 20 Number of teeth on small pulley 20 Revolution of small pulley 600rpm Center distance 600mm Calculation results Initial tension (min) 12.66N Initial tension (max) 19.12N Static shaft load (min) 25.32N Static shaft load (max) 38.24N Deflection 9.60mm Deflection load (min) 1.04N Deflection load (max) 1.45N
