I just changed belts on my core X/Y and in trying to set it up again I have somehow screwed up (of course). X and Y home correctly but when I go to home Z axis the bed drops as expected and goes up as expected but keeps going right into the print head and would keep going if I don't shut it down. I have set the z offset to something ridiculous like -10 and +10 but get the same behavior. The inductive sensor is working as when the bed gets close enough the light on the sensor triggers. I need a push in the right direction here. Config file attached. Thanks.
