I added BL Touch to CR10S. I used the latest firmware, 2.0.9.1 and going back to pre version 2. When I print a part the Z position on the display says it is at .8mm. It stays there until the actual height exceeds this value, then all is okay. Also the Z axis does not move for the first couple of layers, until next layer exceeds .8mm. I have tried many many things to no avail. Has anyone else seen this?
Thanks,
Dick
