I usually end up having to repair something on my printer about once every 2 years. In particular, the adhesive that holds the heater and PEI to the bed plate is good for about 2 years, then lets go. I solved the heater problem by using high temperature silicone to attach it to the bed plate, about 3 years ago, IRIC. I noticed that the PEI is starting to lift at one corner again- it's been a couple years since I last installed it, so time for a refresh.
The rest of the machine doesn't require much other maintenance. I recently put some lube on the guide rails for the first time in a few years. I used a Duet controller board that has drivers soldered to the board, so they don't overheat, and current is set by gcode commands in the config file- there are no tiny pots to break. I used a reliable MeanWell power supply to power everything. I generally prefer to keep things simple because simple often translates to reliable. For example, I have a 5" 220V fan connected to 117V when the machine powers up, blowing across the controller board whenever the machine is powered on. The fan turns slowly and quietly and keeps the board from heating up. Some people want to put in thermostatically controlled fans, but that's an added complication for minimal benefit- the fan won't turn on until the board heats up. Why not just keep it from heating up in the first place?
Many people think they want auto tramming because they remember the bad old days of having to manually retram the bed every time they tried to print. It never occurred to them to ask why the bed went out of tram, and to fix that problem. They just threw more complication in to handle it with a combo of additional hardware and software. New 3D printer people see youtube videos of printers tramming the beds automatically and think it's cool, so they want that, often without knowing the purpose of tramming the bed. Now all the printer makers include it. Auto tramming is a chicken and egg problem. People think they
want auto tramming, so they use multiple motors to drive the Z axis, but if you use multiple motors, you
need auto tramming because the motors get out of sync and that tilts the bed. In the bad old days, people used multiple motors because they thought it was cheaper/easier than connecting the screws to a single motor with a loop belt. Then they struggled with bed tramming because the bed (or X axis) would tilt when the motors were powered up. It took a while to realize that the motors jumping was causing that problem. What people really want, whether they realize it or not, is a machine that gets the first print layer to stick reliably without having to retram the bed manually, over and over. If you never let the screws or belts that lift the bed get out of sync, the bed won't tilt and you won't need to keep retramming it. That is easily accomplished by driving all Z axis screws or belts with one motor.
In UMMD the bed is lifted with two belts driven by one motor. The belts can't get out of sync, so the bed can't tilt. If I take the Z axis apart for some reason (it's been a couple years since I did that) I retram the bed manually which takes 1-2 minutes. I think it's been two years since I last retrammed the bed. I don't have to touch it again, even if I stuff the machine into my car, drive it across town and take it back out. The mount is stable and designed using basic rules of geometry -3 points define a plane (not 4!) - and thoughtful placement of those points makes it very quick and easy to retram the bed. The mount is a kinematic type that allows the bed to expand when heated without causing anything to bend. It is very stable because the bed plate is supported on the tramming screw heads, with springs used to hold the bed plate down, not push it up.
Edited 1 time(s). Last edit at 11/03/2022 11:25AM by the_digital_dentist.
Ultra MegaMax Dominator 3D printer: [
drmrehorst.blogspot.com]
