CoreXY X axis wobble
July 18, 2023 09:25AM
A while back I noticed the X axis wobbling a bit in my corexy sand table as the magnet carriage moved back and forth on the X axis (Y position fixed). I decided to check my printer, UMMD, to see if it had the same issue. It did. The data indicated that the period of the wobble was 40 mm which corresponded to the distance the carriage moves with each rev of the drive pulleys (20 teeth, 2mm pitch). I surmised that the problem was probably a poorly drilled drive pulley.
I just got some Gates pulleys from Filastruder to replace the Ali-Express specials that were originally used in the printer and the X axis wobble is gone. The Gates pulleys fit the motor shafts closely- I had to smooth one of the shafts with fine sandpaper to get the pulley to fit (some lock-tite or galling was interfering). The wobble problem was definitely due to a poorly drilled pulley. The Gates pulleys cost about $4.50 each vs the $2 each for the Ali-express crap. I'd say it's well worth the extra couple $ to use well-made pulleys.
The Gates pulleys from Filastruder are not marked in any way and the packaging is plain, so you'd never know they are Gates pulleys, but Filastruder is an officially licensed Gates distributor.
I wrote a blog post on the original problem and will be updating it with new data shortly. See: [drmrehorst.blogspot.com]
Re: CoreXY X axis wobble
August 03, 2023 08:33AM
Here's the new post on this topic: [drmrehorst.blogspot.com]
November 22, 2023 01:31PM
Interesting.
Now that I have found how sensitive a CoreXY can be, this sounds like an explanation for why vertical walls would have ridges like Ruffles potato chips.
Filastruder, for source of good pulleys.
Thanks for the tip!
be well,
DLC
Kits: Folgertech Kossel 2020 upgraded E3Dv6, Tevo Tarantula enhanced parts and dual-head, TronXY X5SA Pro(E3DHemera).
Scratch: Maker-Beam XL Micro Delta, 220x220CoreXY.
Actually bought: Bambu Labs X1 Carbon
November 24, 2023 07:54AM
No, that would be a precision problem. The error is one of accuracy, not precision. A long, flat surface parallel to the printer's X axis would have waves corresponding to the displacement caused by the out of round drive pulley(s). I have never actually seen such a wave.
The stacked potato chip Z surface is more likely caused by using a geared extruder with two drive gears. See [youtu.be]
November 25, 2023 02:50PM
the_digital_dentist
Damn, having only received a dual-gear extruder today to replace a failing 10-year-old home-printed unit I now have a woodgrain effect to look forward to. CHEE!!
It's not that my prints have never had faults - some have had the mange and maybe smallpox; but never the weathered oak effect. Maybe I will find an artistic use for it.
Mike
November 25, 2023 07:00PM
the_digital_dentist
Like an E3D Hemera?
be well,
DLC
