QIDI X-MAX3 issues after update July 08, 2024 04:36PM |
mcu 'mcu': Starting serial connect Loaded MCU 'mcu' 124 commands (v0.12.0-175-g7b490f3e / gcc: (15:12.2.rel1-1) 12.2.1 20221205 binutils: (2.40-2+18+b1) 2.40) MCU 'mcu' config: BUS_PINS_i2c1=PB6,PB7 BUS_PINS_i2c3=PA8,PC9 BUS_PINS_i2c2=PB10,PB11 BUS_PINS_spi3a=PC11,PC12,PC10 BUS_PINS_spi2a=PC2,PC3,PB10 SERIAL_BAUD=250000 RESERVE_PINS_crystal=PH0,PH1 CLOCK_FREQ=84000000 BUS_PINS_spi1a=PB4,PB5,PB3 STATS_SUMSQ_BASE=256 RECEIVE_WINDOW=192 BUS_PINS_sdio=PC12,PD2,PC8,PC9,PC10,PC11 STEPPER_BOTH_EDGE=1 BUS_PINS_i2c1a=PB8,PB9 ADC_MAX=4095 BUS_PINS_spi4=PE13,PE14,PE12 BUS_PINS_spi3=PB4,PB5,PB3 BUS_PINS_spi2=PB14,PB15,PB13 BUS_PINS_spi1=PA6,PA7,PA5 PWM_MAX=255 MCU=stm32f401xc RESERVE_PINS_serial=PA10,PA9 mcu 'MKS_THR': Starting serial connect Loaded MCU 'MKS_THR' 112 commands (v0.12.0-175-g7b490f3e / gcc: (15:12.2.rel1-1) 12.2.1 20221205 binutils: (2.40-2+18+b1) 2.40) MCU 'MKS_THR' config: BUS_PINS_spi0a=gpio0,gpio3,gpio2 BUS_PINS_i2c0h=gpio28,gpio29 BUS_PINS_spi0c=gpio16,gpio19,gpio18 BUS_PINS_spi0d=gpio20,gpio23,gpio22 BUS_PINS_i2c0b=gpio4,gpio5 BUS_PINS_i2c0c=gpio8,gpio9 BUS_PINS_i2c1c=gpio10,gpio11 BUS_PINS_i2c0a=gpio0,gpio1 BUS_PINS_i2c0f=gpio20,gpio21 BUS_PINS_i2c0g=gpio24,gpio25 BUS_PINS_i2c1g=gpio26,gpio27 BUS_PINS_i2c0e=gpio16,gpio17 BUS_PINS_i2c0d=gpio12,gpio13 BUS_PINS_i2c1e=gpio18,gpio19 BUS_PINS_i2c1f=gpio22,gpio23 BUS_PINS_spi1c=gpio24,gpio27,gpio26 BUS_PINS_spi1b=gpio12,gpio15,gpio14 BUS_PINS_spi1a=gpio8,gpio11,gpio10 STATS_SUMSQ_BASE=256 BUS_PINS_i2c1d=gpio14,gpio15 BUS_PINS_i2c1b=gpio6,gpio7 STEPPER_BOTH_EDGE=1 BUS_PINS_i2c1a=gpio2,gpio3 ADC_MAX=4095 PWM_MAX=255 BUS_PINS_spi0b=gpio4,gpio7,gpio6 MCU=rp2040 CLOCK_FREQ=12000000 Unhandled exception during connect Traceback (most recent call last): File "/home/mks/klipper/klippy/klippy.py", line 180, in _connect cb() File "/home/mks/klipper/klippy/mcu.py", line 729, in _connect self._send_config(None) File "/home/mks/klipper/klippy/mcu.py", line 659, in _send_config cb() File "/home/mks/klipper/klippy/mcu.py", line 76, in _build_config state_tag), ffi_lib.free) OverflowError: can't convert negative number to unsigned webhooks client 281473212563752: New connection webhooks client 281473212563752: Client info {'program': 'Moonraker', 'version': 'v0.7.1-609-gbdd0222-dirty'} Internal error during connect: can't convert negative number to unsigned Once the underlying issue is corrected, use the "RESTART" command to reload the config and restart the host software. Printer is halted
Re: QIDI X-MAX3 issues after update July 11, 2024 12:51PM |
