Just a final check
Could someone tell me if what I'm doing will work? Thank You
So set up contains
ATX Power Supply (
Specs) and I am connecting a coupler to it ( yellow I believe is +12v and black is ground) leaving out red(+5v) and its black (I think) and twisting and soldering on 22 gauge wire (rated at 300v 80 Celsius(176 Fahrenheit)) red to black(ground) and black to yellow(+12v)
HERE (I know I know I screwed up, I did not notice that i soldered them backwards in till I took the picture) And connecting that green coupler to the RAMPS 1.3 leaving out the +5volt and its ground.
I wont kill anything right?
This electrical part of the build scares me
