stepper motors build up heat December 07, 2011 07:15PM |
Re: stepper motors build up heat December 07, 2011 08:23PM |
Re: stepper motors build up heat December 07, 2011 08:25PM |
Re: stepper motors build up heat December 07, 2011 09:45PM |
Re: stepper motors build up heat December 08, 2011 02:19AM |
Re: stepper motors build up heat December 08, 2011 04:26AM |
Admin Registered: 19 years ago Posts: 7,883 |
Re: stepper motors build up heat December 08, 2011 04:37AM |
Re: stepper motors build up heat December 08, 2011 02:44PM |
I currently have my Z axis set to half stepping and I need 283 steps (half steps) per mm. So to lose one half step will kill the accuracy of my layer height by +/- 1/283 of a mm or .0035 mm. That's about 1% error for a 0.4 mm layer height and 2% for 0.2 mm height. Are you really going to see a noticeable difference in prints? (Think of the trees and puppies and kittens and snails and such that are being ground up and burned for power right now because of your profligate waste.
I can see the other axes needing to be locked all the time, but Z seems like one you could disable when not in use unless you are doing .01 mm layers like some of the bleeding edgers out there.
Re: stepper motors build up heat December 13, 2011 05:35PM |
Re: stepper motors build up heat December 13, 2011 08:56PM |
Re: stepper motors build up heat December 14, 2011 12:02PM |
Re: stepper motors build up heat December 30, 2011 12:49PM |
Re: stepper motors build up heat March 04, 2017 06:36PM |
Re: stepper motors build up heat March 04, 2017 06:39PM |
Re: stepper motors build up heat March 04, 2017 07:49PM |
Re: stepper motors build up heat March 08, 2017 08:27AM |
Re: stepper motors build up heat March 08, 2017 08:30AM |
