Hello
I'm (re)drawing a Geared Wade's Extruder for a strap .
Using 3mm filament,
What clearance must be previous between extruder block and idle roller block for adjustment (dealing with hobbed bold wear and filament elasticity ) ?
What is the Wade's design space between extruder body and roller block ?
For the moment, I'm thinking to provide 1 mm for wear of the bold and hesitating between 1 or 2 additional mm for elasticity of the wire.
Are filaments (diameter 3 mm) HDPE, PLA, ABS sufficiently elastic to be significantly deformed during passage through the extruder (penetration of the teeth and flattening from the roller)?
Thanks.
Nh3oh, suivez mon projet sur [
deztrap.blogspot.com]
