A wall painting machine
January 30, 2012 11:30PM
Hello RepRapper's !!
I am new to this web site and i need help for my idea. i am in grade 9 and my idea is.........
A Wall painting machine!
I thought that let me make a machine just like a printer which when programmed about the size of the wall ,paints it ...
for the starting ,i have thought that minute gaphics need not be considered but still the wall must be painted and that too with a roller ...
so ,i need a guy who can tweak the program of a printer and make it useful to me...
Regards,
Azad
VDX
Re: A wall painting machine
January 31, 2012 03:16AM
... can it be a spray-bot too? - [hektor.ch]
Viktor
January 31, 2012 07:02AM
its not a spray-bot ,but it has a roller which keeps on moving and the larger unit holding the roller and the paint container moving like the print head of a printer .in a printer ,the paper move ,here ,the machine moves.
VDX
January 31, 2012 07:20AM
... if you google for "wall painting robot", you'll find mostly spray-bots.
Painting with a roll or brush is not so easy and error-proof as with a spray gun ...
Viktor
February 01, 2012 12:04AM
BUT MY IDEA IS NOW A BIT CHANGED.
IT WILL BE A PAINTER MOUNTED ON A CONTROLLED SHOPPING TROLLEY.
WHEN WE FEED THE TYPE OF WALL ,NO OF WINDOWS DOORS,ETC, IT WILL AUTOMATICALLY CREATE A IMAGE USING WHICH IT WILL MOVE THE ROLLER
February 01, 2012 05:41AM
No need to shout
February 01, 2012 05:46AM
Looks good, but room for improvement.
Looks to me like it could do with a third motor to control the tension in the belts, or at least add weight to the print head.
Would a airbrush gun be more effective than cans?? Better control of the flow rate?
VDX
February 01, 2012 06:00AM
... there are many other designs, some of them already in comercial applications with spray-guns.
But Hektor is my favorite because of his simplicity and scalability ...
Viktor
February 02, 2012 09:36AM
i am not making a grahics painter .
i am making just a simple painting machine
February 02, 2012 09:46AM
See this, this and this.
Bob Morrison
Wörth am Rhein, Germany
"Luke, use the source!"
BLOG - PHOTOS - Thingiverse
November 02, 2012 03:10PM
You need not tweak the printer code.
Simply make another robot programmed for painting.
December 01, 2012 02:26AM
i request u for a wall painting machine. how to use it & oil pain use in it
December 02, 2012 02:33AM
hmmm roller painting .... paint feed mechanism will be interesting ...
December 06, 2012 05:29AM
I built a couple of machines based on the concept of hektor.ch but using a pen instead, some some of it is documented on my blog: [fightpc.blogspot.com.es]
I do not think this approach would work well with a paint roller though.
