TODO: UI / 3D improvement
Posted by ZachHoeken
May 15, 2007 09:13PM
TODO: The UI could definitely use some sprucing up. Theres not much to it, and it is still somewhat confusing. Also, there seem to be some minor display bugs. The print process could be made clearer and also, adding a control panel / better prefs would be nice.
Edited 2 time(s). Last edit at 05/15/2007 11:37PM by Zach Hoeken.
Re: TODO: UI / 3D improvement
May 16, 2007 08:25AM
There seems to be minor display bugs in AOI and Kicad also. Is this a Java library problem?
May 16, 2007 09:34AM
If it's the one where your display freezes in AoI that's a problem with OpenGL. Switch that off in AoI and it will stop happening. It tends to happen when you have an ATI card in your PC rather than a Nividia card.
May 16, 2007 10:55AM
No the bugs I am refering to are small areas of screen that don't get redrawn when they should. My machine has Nvidia onboard gfx. Its not a big problem just slightly irritating.
May 16, 2007 09:49PM
there is a special nvidia fix in the linux instructions you might try.
