Crimping molex connectors
March 31, 2012 08:00AM
Hi all,
I have built Generation 7 electronics for use with my Prusa mendel - and it's working out ok so far. The Generation 7 electronics (like most of the electronics solutions I guess) uses Molex connectors for the stepper motors, heaters, and thermistor connections. Because the crimping tools for Molex connections are quite expensive (circa 40 euro), however, I used a needle-nose pliers instead confused smiley. It more or less worked, but the connections aren't as robust as they should be and I'm not entirely happy with the result.
What do you use to make these Molex connections? Did you invest in one of these specialised crimping tools?
Re: Crimping molex connectors
March 31, 2012 08:26AM
I did buy a cheap crimp tool .. and got a cheap retrofit of a cheap chinese import crimper. Looks like they DIYed themselves some jaws that are almost but not quite right, and then failed to bolt them into the tool. The tool itself is OK but without the jaws its useless.
Still, you can get good results with needle nose pliers and practice. Takes time and they don't look as nice, but they do work. A lot of people solder them to reinforce the crimp, but be careful about stiffening the wire, solder infiltrated wire is prone to breaking when flexed.
TC
March 31, 2012 11:28AM
This is a low cost (i.e. $40) general purpose Molex crimp tool. While not as easy to use as the higher grade crimp tools it gets the job done when used properly.
Molex part number 63811-1000...
http://www.molex.com/webdocs/datasheets/pdf/en-us/0638111000_APPLICATION_TOOLIN.pdf
The Molex datasheet above lists the variety of crimp part numbers (series) that it supports. Check to see if it will do the job for you.
From Digikey...
http://search.digikey.com/scripts/DkSearch/dksus.dll?x=0&y=0〈=en&site=us&KeyWords=wm9999-nd
I'm sure you can find this many other places. I just happened to have the DigiKey part number / link available so that you could see the price.
TC
April 01, 2012 09:26AM
Andrew Smith
Good to know I'm not the only person who has resorted to this. My primary concern is that - even if I manage to make robust connections - it's probably a lot slower than with using a crimper (even with practice). Anyway, it's not an issue unless I decide to build another reprap.
TC
[www.molex.com]
Thanks TC. Will look into this.
April 01, 2012 05:54PM
I have a Sanguinololu board with the 0.1" pitch connectors and have soldered all the motor plugs and so on. I generally give a light squeeze with a pair of pliers so that the back end of the connector grips on to the insulation of the wire. I agree with the comment that it can stiffen the wire and make it more likely to break but I plan to tie in the cables so that any movement of the cable is not felt at the connector. Same is true of end-stop switches, where I have soldered on wires but will provide strain relief wherever the switches move.
April 02, 2012 03:05AM
Unless you plan to keep unplugging your cables it could be a problem but mine is set up and then zip tied in place permanently
__________________________________________________________________________
Experimenting in 3D in New Zealand
April 02, 2012 05:24AM
My feeling is that the molex is not needed, or even unwanted.
A better solution would be an RS232..
Still thinking about what would be an even better solution, as in cheaper.
Unplugging would be mandatory if one expects to fiddle around with cnc/engraving, as well as other options
April 02, 2012 05:44AM
> crimping tools?
I dodged the issue by buying a set of ready-made cables with the same connectors in each end and spliced these into the motor cables. Each cable gives me two connectors and enough wire so I don't have to lengthen the leads (the Alltronics' motors had pretty short leads).
If I need to often plug and unplug something that needs more than an amp, I'll use Anderson PowerPole connectors. Those are pretty awesome.
April 05, 2012 04:38PM
Making your own molex connections is an expensive proposition. The crimpers are expensive (engineer pa-21), the ends are expensive and the terminals are expensive.
However, if you love things to be clean and neat then they can't be beat! Their little brother the pa-09 is extremely useful as well...
- akhlut
Edited 1 time(s). Last edit at 04/05/2012 04:41PM by akhlut.
- akhlut
Just remember - Iterate, Iterate, Iterate!
[myhomelessmind.blogspot.com]
April 22, 2012 02:07PM
Have you watched nophead's video?
I wish I had seen this before I wired my Huxley. I ended up leaving some of the the wires too long and then soldered them as well with the result that the pins wouldn't go right to of the end of the socket.
I made the Mendel90 after watching this video and all the crimps went smoothly, much stronger than before and no need for soldering at all.
April 26, 2012 06:41AM
April 26, 2012 08:36AM
> the socket.
I followed this video as well. Works perfectly, although you do need some small needle nose pliers and patiences.
My Reprap blog
jds-reprap.blogspot.com
Rob
July 18, 2012 11:22AM
I use a universal crimp tool, which does about 100 different crimp types (I can't justify having a one trick pony that will only crimp one crimp pin type in my toolbox). You have to crimp the core then the insulator (so two separate presses), but unless you are doing a production run, this small time overhead is more than offset by the tools flexibility/adapatibility...
[www.precisionhandtools.co.uk]
