If the tape is lifting, you might try something nophead came up with. Admittedly he's having the issue with Kapton and a heated bed, but the same principle may help:
Some corners like it hot
Basically, by putting a small bead of plastic close to the edges of parts on the outside of the object, only a few layers high, it keeps pressure on the tape keeping it in place.
Another thing to check is that the bed is clean of solvent before you put the tape down. If you've used cleaning solvent and then put tape down on some of the residue, the glue on the tape will be affected. You want it clean, not only of old glue, but of residue from cleaning fluids.
