Hot-end/extruder issues: 1. filament slipping, 2. delayed filament extrusion April 18, 2012 08:52AM |
Re: Hot-end/extruder issues: 1. filament slipping, 2. delayed filament extrusion April 18, 2012 12:37PM |
Re: Hot-end/extruder issues: 1. filament slipping, 2. delayed filament extrusion April 18, 2012 02:24PM |
Admin Registered: 18 years ago Posts: 7,883 |
Re: Hot-end/extruder issues: 1. filament slipping, 2. delayed filament extrusion April 18, 2012 04:21PM |
Re: Hot-end/extruder issues: 1. filament slipping, 2. delayed filament extrusion April 18, 2012 05:13PM |
Jim K.
Have you tried a filiament guide? I find it works much better.
nophead
The most likely cause for the delay is all the plastic oozing out of the melt chamber during warm up and having to be replaced. You need to prime it before the build so the extruder is full. You then shouldn't get more than a few tens of milliseconds delay when you start extruding.
Wraithnot
I've ordered two different hobbed bolts (one from a seller on ebay and another from ultimachine) and they were completely different. Both worked, but the bolts were different lengths, the hobbing was in a different spot, and the shape and depth of the grooves was completely different. So ordering another hobbed bolt or two from different suppliers might solve your problem.
Wraithnot
As far as the extruder lag goes, in addition to nophead's sage advice, I've also observed a lag between when you click the pronterface button and when the extruder motor moves. If this is what you are experiencing, it hasn't caused me any issues during a real print.
Help: J-Head hot end melting with smoke April 24, 2012 11:44PM |
Re: Hot-end/extruder issues: 1. filament slipping, 2. delayed filament extrusion April 25, 2012 05:31AM |
