Steppers
Posted by redpiperbob
Steppers
March 13, 2011 12:31AM
Hi all
First question I have several steppers of Minebea manufactuer labeled
17PM-K019-06VS
3.4 volt
0.8amp
6 wire
can anyone tell me if these motors are any use for a Mendal build as I cannot find any spec on the web.
They were used in photocopiers.
thanks in advance
Bob
Re: Steppers
March 13, 2011 08:52PM
All the specs you've listed look good, and should work fine. There are two vital numbers missing though.
What size are these steppers? 1.7" between bolts (indicating a nema 17 size) or 2.3" (indicating a nema 23 size) or what?
How much torque are they rated at? They're almost certain to be strong enough for the axises. The extruder requires a little stronger motor, and a randomly selected nema 17 motor has, I think, about a 50/50 chance of being strong enough to use for the extruder. (that last bit is just a guess)
I'm building it with Baling Wire
Re: Steppers
March 14, 2011 02:22AM
Thanks for the reply John the motors are 17's.
I'll give them a try when my bits arrive.
Thanks
Bob
