Hi All
I am currently trying to dial in my E_STEPS_PER_MM for my extruder to work with gcode cut by Skeinforge 40.
I am using
this approach as suggested by araspitfire.
Thing is, I am not getting consistent results when running twice with the same settings... sometimes my extruder motor will skip some steps... one run extruded about 1.5mm too much, whereas the next extruded 4.5mm to little.
I did hear the stepper skip a few times the second run so was wondering what could be causing that.
I am extruding at a feed rate of 50 which the machine seems to cope well enough with.
Any advice would be appreciated.
Cheers
