some question about prusa March 08, 2011 12:21AM |
Re: some question about prusa March 08, 2011 01:30AM |
Re: some question about prusa March 08, 2011 12:01PM |
Admin Registered: 15 years ago Posts: 1,470 |
I would recommend RAMPS, as it is very compact and gives you plenty of expansion room. However, it can be hard to get a hold of the pololu stepper drivers as they are in short supply. Gen6 would work perfectly fine though.Quote
1.Which electronics would be the best/mostUserFriendly ? Im thinking Gen6 cause i assume i wont have to solder a thing, and its just one board.
Resistor is the easiest by far. Both will give you good results. I personally use a MakerGear hotend, which is very nice and compact, but slightly expensive at $70 or so.Quote
2.Which type or extruder hot end would be the least error prone , and give the best results? nichrome or resistor ?
NEMA 23's won't fit a Mendel, and as jcabrer said, the 17's are plenty powerful enough. Just make sure you get a really strong one for the extruder, something around 3 - 4 kg*cm. The degrees per step isn't a big deal, either 1.8 or 0.9 would work. The micro-stepping of the stepper controllers will give you plenty of accuracy either way.Quote
3.What if any, are the benefits of using nema 23's over 17' , and what degree/step would be best ?
I would recommend printing with PLA from the start, which does not require a heated bed or even printing rafts. That's what I did, and you can always move to ABS as well at a later point if you wish.Quote
4.Should i invest in a heated bed right from the start or is it something easily added? Will the electronics used have to be changed to work with the new bed?
Help improve the RepRap wiki!
Just click "Edit" in the top-right corner of the page and start typing. Anyone can edit the wiki! |
Re: some question about prusa March 09, 2011 03:12PM |
Re: some question about prusa March 09, 2011 04:21PM |
Re: some question about prusa March 09, 2011 04:31PM |
Re: some question about prusa March 09, 2011 05:46PM |
Re: some question about prusa March 13, 2011 12:15PM |
Re: some question about prusa March 14, 2011 01:06AM |
Re: some question about prusa March 19, 2011 03:52PM |
Re: some question about prusa March 20, 2011 02:29AM |
