Durbie Prusa + Pronterface not working?
Posted by krupukbwg
April 27, 2012 08:59AM
Why my printer can't move the motor axes with pronterface, whereas pronterface status is connected to the printer.
Please somebody help me....
MM
Re: Durbie Prusa + Pronterface not working?
April 27, 2012 09:30AM
Perhaps no 12V supply?
What electronics, what firmware?
April 27, 2012 11:05AM
Hi nophead,
I check twice on the current source output the result still 12V; my electronic was gen6.d and my firmware is [github.com].
do you have anything to make motor axes move?, and my computer spec was windows 7 ultimate 32-bit.
Thanks a lot for you attention.
MM
April 27, 2012 03:03PM
Try talking to it with a terminal emulator such as Tera Term. If you have the baud rate correct it should print "start" when you hit reset. The type "G1 X10" It should move the X axis 10mm.
