Steps per mm
Posted by christinAlisha
Steps per mm
December 15, 2011 11:43PM
My prusa is using t5 pulleys with 1.9 degree steppers, and 1/8 microstepping. I'm using marlin with a gen6 board and my x and y steps per mm are both set to 29.09. When I measure the movement on both axises there seems to be a variation between the two.
What causes a difference between actual / calculated steps per mm?
Re: Steps per mm
December 16, 2011 12:31AM
Printed pulleys?
Re: Steps per mm
December 16, 2011 04:43AM
I don't think you have 1.9 degree motors, it has to divide exactly into 360, so I think you mean 1.8 or 0.9
With 1.8 motors and and 1/8 stepping there are 1600 steps per rev. The distance travelled is the number of teeth times the belt pitch. With 8 tooth T5 pulleys you would have 40 steps per mm. I can't see how you would arrive at 29.09. Maybe 12 tooth pulleys and a 0.9 motor giving 30 steps / mm.
The only difference between calculated and actual can be the belt pitch, which must vary a little with tension. How are you measuring it? Is there any backlash?
Re: Steps per mm
December 16, 2011 04:49AM
If you measure distances that are a whole number of revolutions of the pulley then that would eliminate inaccuracy due to printed pulleys.
Re: Steps per mm
December 19, 2011 02:34PM
Thanks for the responses,
@nophead I followed your advice and with a demanded movement of 100mm I believe I have the accuracy down to +- .4mm on the X and Y.
Ive also ordered a couple aluminum pulleys to replace the printed ones.
[sdp-si.com]
