Estimated time to print a set of MendelMax 1.0 parts?
May 26, 2012 04:04PM
I'm looking to do a MendelMax 1.0 build. Have pretty much all needed except the printed parts.
I've loaded the file "Lower_Vertex_Lower.stl" into pronterface and got an estimated print time of 2 hrs 47 mins for the one part. To print on my Prusa. This slightly worries me, at this rate it could take quite a while to print out all the MendelMax parts.
(There are 4 of the lower vertices and I counted 74 parts in total, over about 30 different part types).
I need to decide between print myself or buy in ready printed.
I could load each of the STL files into pronterface, and add up the print times, but my slic3r settings may be out.
Anyone printed a full set of MendelMax 1.0 parts - and can indicate approx how many print hours it took?
Thanks in advance
Mike
Prusa Mendel /Parcan Mk 2/1280 RAMPS 1.4/PC XP OS/Pronterface/Sprinter/Slic3r
Edited 1 time(s). Last edit at 05/26/2012 04:05PM by 3D2B.
Re: Estimated time to print a set of MendelMax 1.0 parts?
May 26, 2012 05:10PM
Takes me a week to print a set of Prusa parts on a Sells Mendel
__________________________________________________________________________
Experimenting in 3D in New Zealand
May 26, 2012 05:28PM
Really? It takes me about 24 hours to print a Prusa on my Mendel and it is pretty slow due it an aluminium bed and a big heatsink on the extruder.
May 26, 2012 05:37PM
NelsonRap,
Thanks for the reply. Any idea how many print hours that week represents?
Mike
May 26, 2012 06:32PM
If I print a few parts each weeknight and all day during the weekend, it takes me about a week to print a full set including X axis, Y carriage, and a Greg's Wades extruder. Thats with 40% infill on most parts and layer height of .25mm using a 0.50mm nozzle.
May 26, 2012 07:19PM
Somewhere around 20-25 hours I guess as I don't run it all day only in the mornings while I'm the only one home as the workshop is under the lounge and the noise comes up through the floor
May 27, 2012 05:35AM
I adjusted my slic3r settings for 'fast' , set to 40% infill on most parts and layer height of .25mm as per Mkouri's note above.
Loaded the files into pronterface and added up the estimated times:
Top_Vertex_X_4_off.stl 64 (ie 4 x 16 mins = 64 mins)
Lower_Vertex_Middle_4_off.stl 112
Z_Motor_Mount_2_off.stl 102
Y_Rod_Mount_2_off.stl 88
Top_Rod_Jig_70mm.stl 25
Top_Vertex_X_logo_optional.stl 21
Z_Rod_Lower_Mount_2_off.stl 88
Y_Rod_Setting_Jig.stl 7
Top_Vertex_Y_2_off.stl 34
LowerVertex_4_off.stl 84
Z_rod_clasp_4_off.stl 28
LowerVertex_cupcake.stl 18
Y_Idler_Mount.stl 14
Y_Motor_Mount.stl 41
Lower_Vertex_Lower.stl 85
Lower_Vertex_Upper.stl 67
Y_Rod_Clasp_4_off.stl 20
Total mins 898
So around 15 hours , excluding the extruder
If you add in an extruder, and go slower for some parts, 20-25 hours sounds a reasonable estimate.
Prusa Mendel /Parcan Mk 2/1280 RAMPS 1.4/PC XP OS/Pronterface/Slic3r
In the UK, down south & over to the left you'll find the West of England RUG.
For details, visit tiny.cc/woereprap or tiny.cc/woerug
