Printing in wrong scale..
Posted by toreil
September 19, 2012 01:57AM
Hi
Im strugeling to get my first print right..It's to big..
Im drawing up a cube with a cuple of holes in sketchup, export it to .STL and opens it in pronterface.
All looks fine, in the pronterface panel the messures look right 50x50x15 mm
I start print and it's all goes wrong.
The mec, findes it home pos, ad starts almost all over my 200x200 hotplate,
Can anyone please give a hint on this, have looked over the settings, but cant find anything
that have with scale to do..
Best Tore
Re: Printing in wrong scale..
September 19, 2012 06:45AM
Could be your stepper motor settings in firmware. Check the steps per revolution and also whether you stepper drivers support 8x microstepping or 16x. This is the most common reason why you get scaling problems.
September 19, 2012 02:25PM
Hi
Have checked some of this, I got the 200 steps /rew stepper 1.8 degr.
The straps on the board is 'all inn' wich if I read the table correct is 1/16, and the fw is standard sprinter
Does this say anything, As a newbie I'm not to keen on doing things in the firmware.. guess things dont work at all
if I do this..
Can some of this info be of any assistance in finding the problem ??
Best tore
September 19, 2012 02:49PM
You have to set up the firmware to match the hardware, it generally, unless provided by a kit manufacturer doesn't just work.
