I'm trying to configure my Y-Stop (1) to be a maximum, so that when I hit home Y slides to the max stop and stops.
So, I've set the following:
#define X_HOME_DIR -1
#define Y_HOME_DIR 1
#define Z_HOME_DIR -1
placed a jumper on the minimum-Y stop,
set my switch on maximum-Y (which is wired NC)
however, when I hit Y-Home in Pronto it does nothing. If I hold my Y-Max stop, the board allows me to keep moving it... and when I release it. If I swap the Y-Max switch onto the Y-Min connector the board will only move Y+.when it is pressed.
