Want gegs extruder in skp format
Posted by gregted
May 31, 2012 09:44PM
I want to slightly modify gregs accessible extruder to add a thicker hinge joint and was wondering if anyone has a link to a skp file.
Re: Want gegs extruder in skp format
June 01, 2012 03:58AM
Why not just import the STL?
garyhodgson.com/reprap | reprap.development-tracker.info | thingtracker.net
June 02, 2012 06:57AM
Thanks Gary,
Don't know why I didn't think of that... Doh
June 02, 2012 03:17PM
Was looking into this as well. the hinge door on mine cracked at the bottom where the screw goes through.
Would be great if you can share it here once its done :-)
Jonas
June 02, 2012 05:10PM
I just put a bolt through mine instead of using a screw
__________________________________________________________________________
Experimenting in 3D in New Zealand
June 03, 2012 08:25AM
I also use a 3mm bolt but still have a problem with the hinge breaking.
I will try to modify the stl but in the meantime I have designed a filament guide to glue onto the standard hinge that seems to print out ok and is stronger. This is on thingiverse.
[www.thingiverse.com]
If the hinge printed on its side, the hinge would be a continuous bead around the hole but all the support would be a pain to clean up, still Might try this anyway.
